| 0001759 | FreeCAD | Bug | public | 2014-09-20 10:01 | 2014-12-29 00:37 |
| Reporter | shoogen | Assigned To | |||
| Priority | low | Severity | major | Reproducibility | always |
| Summary | 0001759: python interface allows to break sketches by invalid GeomIds | ||||
| Description | currently neither the Constraint constructor nor the addConstraint method check, if the supplies geomIds are valid. This leads to broken sketches. addConstraint should raise an exception, if the referenced Geometry (or Sub-Geometry) is not present in the Sketch. Currently the sketcher does not perform any integrity checks resulting in exiting due to assertions fails and crashes due to out-of-bounds memory access. Despite the fact that FreeCAD should not crash because of invalid sketches, those sketches should be handled gracefully. This means marking them with a exclamation mark in tree view. And allowing to delete offending constraints in the task view. But it should not be easy for a user to create such a sketch from the python interface. | ||||
| Tags | sketcher | ||||
| 2014-09-20 10:01 | shoogen | New Issue | |
| 2014-09-20 10:02 | shoogen | Relationship added | related to 0001720 |
| 2014-09-20 10:02 | shoogen | Tag Attached: sketcher | |
| 2014-12-29 00:37 | wmayer | Note Added: 0005461 | |
| 2014-12-29 00:37 | wmayer | Status | new => closed |
| 2014-12-29 00:37 | wmayer | Resolution | open => fixed |
| 2014-12-29 00:37 | wmayer | Fixed in Version | => 0.15 |
