| 0001764 | FreeCAD | Bug | public | 2014-09-24 11:51 | 2014-11-07 18:09 |
| Reporter | thor | Assigned To | |||
| Status | closed | Resolution | open | ||
| Summary | 0001764: Cannot sweep a circle section along a curved edge as solid | ||||
| Description | In the sweep panel, with the "Solid" checkbox marked, If the sketch being sweeped contains a circle section, and at least one of the continuous edges it is swept along is not straight, the result won't be a solid. The ends are left open, in the Data panel it will claim "Solid: True", but nothing that expects a solid will work. With only one straight edge, a sketch with a circle section can be sweeped as solid just fine. A single full circle can be swept along several straight and curved edges, but as soon as you cut the circle (still creating one closed shape), it won't work anymore. | ||||
| Additional Information | From About: OS: Ubuntu 14.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4061 (Git) Branch: master Hash: e08788eca90b51a33f4d045778e2cf8a3ef3fade Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.1 | ||||
Is there a sample fcstd file? In CircleSweep1764, a partial circle profile sweeps along a curved path successfully. OS: Ubuntu 12.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4150 (Git) Branch: master Hash: 267ca0813a20a3d7c04b4affae5d45f6d5187966 Python version: 2.7.3 Qt version: 4.8.1 Coin version: 3.1.3 OCC version: 6.7.0 |
With 0.15.4159, the bug is gone. After not being able to trigger it with a simplified example, I went back to the complicated construction that led to the bug report. All fine now, this can be closed. Thank you for looking into this! |
| 2014-09-24 11:51 | thor | New Issue | |
| 2014-09-24 13:14 | shoogen | Relationship added | related to 0001419 |
| 2014-11-06 23:02 | wandererfan | File Added: CircleSweep1764.fcstd | |
| 2014-11-06 23:05 | wandererfan | Note Added: 0005285 | |
| 2014-11-06 23:06 | wandererfan | Status | new => feedback |
| 2014-11-07 17:50 | thor | Note Added: 0005287 | |
| 2014-11-07 17:50 | thor | Status | feedback => new |
| 2014-11-07 18:09 | wandererfan | Status | new => closed |
