| 0001768 | FreeCAD | Feature | public | 2014-09-30 13:43 | 2015-01-03 16:59 |
| Reporter | jmaustpc | Assigned To | yorik | ||
| Summary | 0001768: Draft Array creates an invalid compound when component solids intersect with each other | ||||
| Description | Draft Array creates an invalid compound when component solids intersect with each other. Could we add some ability, one way or another, to create a Fuse Boolean in this case, rather than a compound, so that the out put would be valid? Part Fuse when run on non-intersecting solids creates a fuse that is a compound of two solids, much the same thing as a Draft Array? So wouldn't it make sense to just make all Draft Arrays run a Fuse underneath then if they intersect you get a a valid compound containing one single solid and if the component solids of the Draft Array do not intersect you would get a valid compound of several solids? | ||||
This should be an option, not a default. Fusion of many complex shapes in an array can consume more than a little time, and possibly fail. |
I tend to agree with quick... Fusing is a very heavy operation, while compound is really fast. And the Draft array is rarely used for fusing I think. We could of course add an option for it... |
+1. I needed such a feature a couple of times. Although I worked around (used clone in one case and linear feature pattern in the other case), the workarounds were less convenient than a fused array would have been. +1 for optionality. Or: integrate such a fusing into Part/Fuse tool, by allowing an object to be fused with itself. That is where I naturally was looking for it. |
| 2014-09-30 13:43 | jmaustpc | New Issue | |
| 2014-09-30 13:43 | jmaustpc | Status | new => assigned |
| 2014-09-30 13:43 | jmaustpc | Assigned To | => yorik |
| 2014-09-30 16:51 | quick61 | Note Added: 0005168 | |
| 2014-09-30 22:11 | yorik | Note Added: 0005170 | |
| 2014-10-24 21:13 | DeepSOIC | Note Added: 0005251 | |
| 2014-10-24 21:14 | DeepSOIC | Note Edited: 0005251 | |
| 2015-01-03 16:59 | yorik | Changeset attached | => FreeCAD Master master 3db987d9 |
| 2015-01-03 16:59 | yorik | Status | assigned => closed |
| 2015-01-03 16:59 | yorik | Resolution | open => fixed |
