| 0001771 | FreeCAD | Bug | public | 2014-09-30 18:01 | 2015-01-02 19:20 |
| Reporter | quick61 | Assigned To | yorik | ||
| Summary | 0001771: Raytracing Workbench - LuxRender Error | ||||
| Description | When trying to produce a LuxRender scene from the Raytracing Workbench, FreeCAD produces an error and fails. | ||||
| Steps To Reproduce | Switch to Raytracing Workbench Select either LuxClasic or LuxOutdoor template. Select object to be included in scene. Select Insert a new part object into a Reatracing project The object is not inserted into the Raytracing project and produces the following error - Traceback (most recent call last): File "<string>", line 1, in <module> <type 'exceptions.AttributeError'>: 'App.DocumentObject' object has no attribute 'Transparency' Stack Trace: Traceback (most recent call last): File "<string>", line 1, in <module> | ||||
| Additional Information | FreeCAD Forum thread, Issues with LuxRender - http://forum.freecadweb.org/viewtopic.php?f=3&t=7844 | ||||
| Tags | Raytracing | ||||
| 2014-09-30 18:01 | quick61 | New Issue | |
| 2014-09-30 18:03 | quick61 | Tag Attached: Raytracing | |
| 2014-09-30 22:09 | yorik | Note Added: 0005169 | |
| 2014-09-30 22:09 | yorik | Assigned To | => yorik |
| 2014-09-30 22:09 | yorik | Status | new => assigned |
| 2015-01-02 19:20 | yorik | Changeset attached | => FreeCAD Master master 1dd069ec |
| 2015-01-02 19:20 | yorik | Status | assigned => closed |
| 2015-01-02 19:20 | yorik | Resolution | open => fixed |
