| 0001773 | FreeCAD | Bug | public | 2014-10-01 20:14 | 2015-01-15 20:19 |
| Reporter | microelly2 | Assigned To | yorik | ||
| Platform | ubuntu and win | ||||
| Summary | 0001773: Drawing of dashed lines works only for scale=20 | ||||
| Description | the dashed lines generated ind draft are correct displayed only with the (default) scale factor 20 http://forum.freecadweb.org/viewtopic.php?f=3&t=7840 | ||||
| Steps To Reproduce | generate a draft rectangle format line style to dash project it to a drawing sheet reduce the scele to 1 | ||||
Line width does not scale with XY. This can be adjusted in the Data tab of the dashed line in question. Should we be scaling the line width along with the XY? Also, Priority and Severity should be downgraded on this. It's not even close to causing any sort of crash. |
Hm indeed, I hadn't noticed that.. I'm not sure if/how it is possible to have scale-independent dashes in SVG, but I'll have a look. |
| 2014-10-01 20:14 | microelly2 | New Issue | |
| 2014-10-01 20:34 | quick61 | Note Added: 0005173 | |
| 2014-10-01 20:35 | quick61 | Note Edited: 0005173 | |
| 2014-10-01 22:01 | yorik | Note Added: 0005176 | |
| 2014-10-01 22:02 | yorik | Assigned To | => yorik |
| 2014-10-01 22:02 | yorik | Status | new => assigned |
| 2014-10-01 22:02 | yorik | Priority | high => low |
| 2014-10-01 22:02 | yorik | Severity | major => minor |
| 2015-01-15 20:19 | yorik | Changeset attached | => FreeCAD Master master 9de49259 |
| 2015-01-15 20:19 | yorik | Status | assigned => closed |
| 2015-01-15 20:19 | yorik | Resolution | open => fixed |
