0001774FreeCADBugpublic2014-10-02 09:36
Reporternitinsane Assigned To
PlatformMicrosoftOSwindowsOS Version7
Product Version0.14
Fixed in Version0.15
Summary0001774: only two tabs are shown in Edit -> preferences dialog
Descriptionthe documentation talks about draft icon in the preferences. I have installed (and reinstalled) 0.14 but I don't see this. Screenshot is attached.
nitinsane
2014-10-01 21:20
reporter
nitinsane
2014-10-01 21:25
reporter   ~0005174
Well, after I selected draft in the drop-down on the main screen, draft entry appeared in the preferences dialog. This is not intuitive. The settings here should be global.
quick61
2014-10-01 21:28
reporter   ~0005175
You must open up the other workbenches to see their related Preference settings. To see and have assess to the Draft Preferences, you must first switch to the Draft Workbench, then go to Edit > Preferences. Same for Part Design, Raytracing, etc..
This is not a bug.
Also, it would of been better to of asked about this on the FreeCAD forum before filing a bug report.
2014-10-02 09:36
administrator   ~0005178
Sure, it is somewhat inconvenient to actively load a workbench before you can access its user settings. However, it is much more important to have short start times of the application by not loading all available application modules (plug-ins).
2014-10-01 21:20 nitinsane New Issue
2014-10-01 21:20 nitinsane File Added: Capture.PNG
2014-10-01 21:25 nitinsane Note Added: 0005174
2014-10-01 21:28 quick61 Note Added: 0005175
2014-10-01 21:31 quick61 Note Edited: 0005175
2014-10-02 09:36 wmayer Note Added: 0005178
2014-10-02 09:36 wmayer Status new => closed
2014-10-02 09:36 wmayer Resolution open => not fixable
2014-10-02 09:36 wmayer Fixed in Version => 0.15
