| 0001787 | FreeCAD | Bug | public | 2014-10-13 21:42 | 2014-11-03 12:51 |
| Reporter | microelly2 | Assigned To | yorik | ||
| Summary | 0001787: draft patharray with align does not use the correct direction | ||||
| Description | the object is not directed to the tangent I think: if (x,y) is the tangent direction then the object copy is directed to (-x,y) | ||||
| Steps To Reproduce | see example file the clone of wire are scaled with (-1,1,0) relative to the base wire the rectangle-copies are well directed to the clones of wire but not tangential to the wire itself | ||||
| 2014-10-13 21:42 | microelly2 | New Issue | |
| 2014-10-13 21:42 | microelly2 | File Added: m02_path_array_error.fcstd | |
| 2014-10-13 23:47 | yorik | Assigned To | => yorik |
| 2014-10-13 23:47 | yorik | Status | new => assigned |
| 2014-11-03 12:27 | yorik | Assigned To | yorik => wandererfan |
| 2014-11-03 12:51 | yorik | Changeset attached | => FreeCAD Master master fc6d57f8 |
| 2014-11-03 12:51 | yorik | Assigned To | wandererfan => yorik |
| 2014-11-03 12:51 | yorik | Status | assigned => closed |
| 2014-11-03 12:51 | yorik | Resolution | open => fixed |
