| 0001789 | FreeCAD | Bug | public | 2014-10-16 15:35 | 2014-12-31 17:09 |
| Reporter | balazs | Assigned To | yorik | ||
| Platform | Linux | OS | Debian | OS Version | Wheezy |
| Summary | 0001789: FreeCAD crashes during arch example rotation | ||||
| Description | FreeCAD crashes during arch example rotation Kernel is 3.2.0-4-amd64 | ||||
| Steps To Reproduce | start FreeCAD open data/examples/ArchDetail.FCStd click tab ArchDetail : 1 click Set front view (1) - I see it only in Hungarian, it is a cube with the lower left face facing us filled with blue. However, other views make it too. | ||||
| Additional Information | Traceback (most recent call last): File "/opt/tmp/free-cad-code/Mod/Arch/ArchSectionPlane.py", line 182, in attach self.onChanged(vobj,"DisplayLength") File "/opt/tmp/free-cad-code/Mod/Arch/ArchSectionPlane.py", line 209, in onChanged ld = vobj.DisplayLength.Value/2 <type 'exceptions.AttributeError'>: 'Gui.ViewProviderPythonFeature' object has no attribute 'DisplayLength' Traceback (most recent call last): File "/opt/tmp/free-cad-code/Mod/Arch/ArchSectionPlane.py", line 197, in updateData self.onChanged(obj.ViewObject,"DisplayLength") File "/opt/tmp/free-cad-code/Mod/Arch/ArchSectionPlane.py", line 209, in onChanged ld = vobj.DisplayLength.Value/2 <type 'exceptions.AttributeError'>: 'Gui.ViewProviderPythonFeature' object has no attribute 'DisplayLength' Coin error in SoIndexedShape::computeBBox(): coordinate index nr 1 for <unnamed> node of type IndexedFaceSet is out of bounds: is 1, but no coordinates are available from the state! Coin error in SoIndexedShape::computeBBox(): coordinate index nr 1 for <unnamed> node of type IndexedFaceSet is out of bounds: is 1, but no coordinates are available from the state! Coin error in SoIndexedShape::computeBBox(): coordinate index nr 1 for <unnamed> node of type SoBrepEdgeSet is out of bounds: is 1, but no coordinates are available from the state! Coin error in SoIndexedShape::computeBBox(): coordinate index nr 1 for <unnamed> node of type SoBrepEdgeSet is out of bounds: is 1, but no coordinates are available from the state! Coin warning in SoNormalCache::generatePerFace(): Polygon with less than three valid vertices detected. (offset: 0, [0 1 2]). Should be within [0, 0]. Coin warning in SoNormalCache::generatePerFace(): Polygon with less than three valid vertices detected. (offset: 2, [2 -1 0]). Should be within [0, 0]. Coin warning in SoNormalCache::generatePerFace(): Polygon with less than three valid vertices detected. (offset: 3, [-1 0 2]). Should be within [0, 0]. Coin warning in SoNormalCache::generatePerFace(): Polygon with less than three valid vertices detected. (offset: 4, [0 2 3]). Should be within [0, 0]. Coin warning in SoNormalCache::generatePerFace(): Face specification did not end with a valid polygon. Too few points FreeCAD: SoCoordinateElement.cpp:169: const SbVec3f& SoCoordinateElement::get3(int) const: Assertion `index >= 0 && index < this->numCoords' failed. Félbeszakítva (interrupted) | ||||
| 2014-10-16 15:35 | balazs | New Issue | |
| 2014-10-16 15:37 | balazs | Note Added: 0005222 | |
| 2014-10-16 17:23 | yorik | Assigned To | => yorik |
| 2014-10-16 17:23 | yorik | Status | new => assigned |
| 2014-12-31 17:09 | yorik | Changeset attached | => FreeCAD Master master 3f607d73 |
| 2014-12-31 17:09 | yorik | Status | assigned => closed |
| 2014-12-31 17:09 | yorik | Resolution | open => fixed |
