| 0001793 | FreeCAD | Bug | public | 2014-10-22 00:24 | 2014-11-28 02:37 |
| Reporter | Dieter Nuetzel | Assigned To | yorik | ||
| Priority | low | Severity | crash | Reproducibility | always |
| Platform | x86 32 bit | OS | Linux | OS Version | 3.18-rc |
| Summary | 0001793: 0.15 git crash always during load of 'LoadArchExample.py' | ||||
| Description | Since several weeks FreeCAD 0.15, Libs: 0.15R4029 (Git) (Packman) crash all the time during load of 'LoadArchExample.py' (Lade ein Architektur Beispiel-Modell). Worked OK with FreeCAD 0.14 release AND early 0.15 git versions. | ||||
| Steps To Reproduce | 1. Start FreeCAD 2. try to open 'Lade ein Architektur Beispiel-Modell' from 'Beispiel-Projekte' 3. the first window (2D view) appears 4. crash during 3D view | ||||
| Additional Information | /opt/mesa> FreeCAD FreeCAD 0.15, Libs: 0.15R4029 (Git) (Packman) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## ATTENTION: default value of option vblank_mode overridden by environment. Traceback (most recent call last): File "/usr/lib/FreeCAD/Mod/Arch/ArchSectionPlane.py", line 182, in attach self.onChanged(vobj,"DisplayLength") File "/usr/lib/FreeCAD/Mod/Arch/ArchSectionPlane.py", line 209, in onChanged ld = vobj.DisplayLength.Value/2 <type 'exceptions.AttributeError'>: 'Gui.ViewProviderPythonFeature' object has no attribute 'DisplayLength' Traceback (most recent call last): File "/usr/lib/FreeCAD/Mod/Arch/ArchSectionPlane.py", line 197, in updateData self.onChanged(obj.ViewObject,"DisplayLength") File "/usr/lib/FreeCAD/Mod/Arch/ArchSectionPlane.py", line 209, in onChanged ld = vobj.DisplayLength.Value/2 <type 'exceptions.AttributeError'>: 'Gui.ViewProviderPythonFeature' object has no attribute 'DisplayLength' Coin error in SoIndexedShape::computeBBox(): coordinate index nr 1 for <unnamed> node of type IndexedFaceSet is out of bounds: is 1, but no coordinates are available from the state! Coin error in SoIndexedShape::computeBBox(): coordinate index nr 1 for <unnamed> node of type IndexedFaceSet is out of bounds: is 1, but no coordinates are available from the state! Coin error in SoIndexedShape::computeBBox(): coordinate index nr 1 for <unnamed> node of type SoBrepEdgeSet is out of bounds: is 1, but no coordinates are available from the state! Coin error in SoIndexedShape::computeBBox(): coordinate index nr 1 for <unnamed> node of type SoBrepEdgeSet is out of bounds: is 1, but no coordinates are available from the state! Coin warning in SoNormalCache::generatePerFace(): Polygon with less than three valid vertices detected. (offset: 0, [0 1 2]). Should be within [0, 0]. Coin warning in SoNormalCache::generatePerFace(): Polygon with less than three valid vertices detected. (offset: 2, [2 -1 0]). Should be within [0, 0]. Coin warning in SoNormalCache::generatePerFace(): Polygon with less than three valid vertices detected. (offset: 3, [-1 0 2]). Should be within [0, 0]. Coin warning in SoNormalCache::generatePerFace(): Polygon with less than three valid vertices detected. (offset: 4, [0 2 3]). Should be within [0, 0]. Coin warning in SoNormalCache::generatePerFace(): Face specification did not end with a valid polygon. Too few points FreeCAD: SoCoordinateElement.cpp:169: const SbVec3f& SoCoordinateElement::get3(int) const: Assertion `index >= 0 && index < this->numCoords' failed. Abbruch | ||||
I'll have a look |
Works for me since 26.11.2014. One version before this one: FreeCAD 0.15, Libs: 0.15R4221 (Git) (Packman) FreeCAD-0.15.99+git20141126.1336-1.1.src.rpm Thank you very much for this GREAT software! |
Fixed by commit 58a84d274821b8ff3f5df20e87fb327d4d3d8ce9 Could be closed, too. |
Ah indeed.. I had forgotten about this one :) |
| 2014-10-22 00:24 | Dieter Nuetzel | New Issue | |
| 2014-10-22 02:04 | yorik | Assigned To | => yorik |
| 2014-10-22 02:04 | yorik | Status | new => assigned |
| 2014-10-22 02:05 | yorik | Priority | high => low |
| 2014-10-22 02:05 | yorik | Note Added: 0005245 | |
| 2014-11-28 02:01 | Dieter Nuetzel | Note Added: 0005346 | |
| 2014-11-28 02:26 | Dieter Nuetzel | Note Added: 0005347 | |
| 2014-11-28 02:36 | yorik | Note Added: 0005348 | |
| 2014-11-28 02:36 | yorik | Relationship added | duplicate of 0001836 |
| 2014-11-28 02:37 | yorik | Status | assigned => closed |
| 2014-11-28 02:37 | yorik | Resolution | open => duplicate |
| 2014-11-28 02:37 | yorik | Fixed in Version | => 0.15 |
