0001800FreeCADBugpublic2014-11-09 16:08
Reporterfollower Assigned Towmayer
Status closedResolutionfixed
PlatformMacBook ProOSMac OS XOS Version10.8.5
Product Version0.14
Fixed in Version0.15
Summary0001800: Redraw does not work with MSAA Anti-Aliasing selected
DescriptionWhen one of the MSAA Anti-Aliasing schemes is selected the model display area is not re-drawn/re-painted when Sketch mode is exited.
Note: This is on a MacBook Pro with "Intel HD Graphics 4000" & "NVIDIA GeForce GT 650M".
Steps To ReproduceChange Display > 3D View > Anti-Aliasing to MSAA 2x (or 4x or 8x)
Create new document (In "Complete" mode)
Create a new sketch
Close the sketch
(Observe that the sketch grid etc is still displayed.)
Change the Anti-Aliasing mode to None or Line smoothing and observe the sketch grid is not displayed when following the same steps.
(Optionally add a cylinder before the sketch and observe the display is not updated )
Additional InformationOS: Mac OS X
Word size: 64-bit
Version: 0.14.3703 (Git)
Branch: releases/FreeCAD-0-14
Hash: c6edd47334a3e6f209e493773093db2b9b4f0e40
Python version: 2.7.5
Qt version: 4.8.6
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
follower
2014-10-24 13:32
reporter   ~0005250
This comment might be relevant: "I found a regression when anti-aliasing is on. Whenever you draw into the front buffer (happens with the mesh cutting/trimming or the rubberband selection in the sketcher) the repainting doesn't work properly any more" (via http://forum.freecad.org/viewtopic.php?p=52839#p52839)
DeepSOIC
2014-10-24 22:21
developer   ~0005252
Not reproduced on:
OS: Windows 8.1
Word size: 64-bit
Version: 0.14.3700 (Git)
Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1
Python version: 2.7.6
Qt version: 4.8.5
SoQt version: 1.6.0a
OCC version: 6.6.0
Intel HD Graphics 4000 on Sony Vaio Duo 11
Although I do get a strange transient grey screen when I close or open the sketch.
Anyway... In current development version the 3D viewer has changed (http://forum.freecad.org/viewtopic.php?f=10&t=7486), so the bug is likely irrelevant.
DanStory
2014-10-28 15:54
reporter   ~0005260
I was also able to reproduce it.
OS: Mac OS X
Word size: 64-bit
Qt version: 4.8.6
Coin version: 3.1.3
SoQt version: 1.5.0
System Info:
MacBook Pro (Retina, 13-inch, Late 2013)
CPU: 2.4 GHz Intel Core i5
RAM: 16 GB 1600 MHz DDR3
GPU: Intel Iris 1536 MB
2014-11-09 16:08
administrator   ~0005293
It seems this happened only with SoQt. The current development branch has moved to the more modern Quarter library and there it works.
2014-10-24 13:31 follower New Issue
2014-10-24 13:32 follower Note Added: 0005250
2014-10-24 22:21 DeepSOIC Note Added: 0005252
2014-10-28 15:54 DanStory Note Added: 0005260
2014-11-09 16:08 wmayer Note Added: 0005293
2014-11-09 16:08 wmayer Status new => closed
2014-11-09 16:08 wmayer Assigned To => wmayer
2014-11-09 16:08 wmayer Resolution open => fixed
2014-11-09 16:08 wmayer Fixed in Version => 0.15
