| 0001807 | FreeCAD | Feature | public | 2014-10-27 15:45 | 2015-01-07 18:37 |
| Reporter | microelly2 | Assigned To | yorik | ||
| Summary | 0001807: Spreadsheet - Cell Controller confusing label in Property Dialog | ||||
| Description | The Filter Type Target Name is a little bit confusing The Filter works on the Object.Label and NOT on Object.Name Spreadsheet.py line 528 | ||||
@ thomas sounds like a good point. @ Yorik since we are getting a new spreadsheet workbench that generally works without a cell controller etc.... should we just close this ticket even though it presumably was a good point with regards to the soon to be obsolete code? Or do you want to fix it in the old wb first? Jim |
No I think we can close this... The new spreadsheet is very close to be merged, and indeed this bug report will be made obsolete by it. @microelly2 feel free to reopen if needed, but normally there will be no more work on the current spreadsheet controllers... |
| 2014-10-27 15:45 | microelly2 | New Issue | |
| 2015-01-07 15:27 | jmaustpc | Note Added: 0005557 | |
| 2015-01-07 18:37 | yorik | Note Added: 0005568 | |
| 2015-01-07 18:37 | yorik | Status | new => closed |
| 2015-01-07 18:37 | yorik | Assigned To | => yorik |
| 2015-01-07 18:37 | yorik | Resolution | open => won't fix |
| 2015-01-07 18:37 | yorik | Fixed in Version | => 0.15 |
