| 0001809 | PartDesign | Bug | public | 2014-10-31 19:12 | 2014-12-08 14:27 |
| Reporter | DeepSOIC | Assigned To | |||
| Platform | 64-bit | OS | Windows | OS Version | 8.1 |
| Summary | 0001809: Pocketing "Up to face" fails when sketch extends out of the part | ||||
| Description | Consider I have a box and I want to cut a slot in it. I map a sketch to a face and draw a rectangle that intersects an edge of the face. When pocketing the sketch, it sound like a good idea to pocket to the opposite face of the box. But when I do so, I get an error message (title)"Input error" (message)"ACCESS VIOLATION at address 0x00000000 during 'READ' operation". After that the task remains active. | ||||
| Steps To Reproduce | 1. Create a box (either by padding a sketch or by a command on Part WB) 2. Select a face of the box and map a new sketch onto it 3. In the new sketch, draw a rectangle that intersects the face the sketch is mapped to. Close the sketch. 4. Click Pocket on Part Design WB. In Type dropdown, select "Up to face". Click a Face button, rotate 3d view and click a face of the box that is the opposite to the face the sketch was mapped to. 5. Click OK. A message box pops up: (title)"Input error" (message)"ACCESS VIOLATION at address 0x00000000 during 'READ' operation". The task remains active and 3d view is showing the pocket of a dimension style. --------OR 1. Open the attached file. 2. In tree view, double click on Pocket 3. Click OK. | ||||
| Additional Information | OS: Windows 8.1 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4151 (Git) Branch: master Hash: ae09625140651423ed7b1035fa59395d206e532f Python version: 2.7.5 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.0 It does not happen on FC 0.14 64-bit. It apparently only happens when the sketch extends out of the face. But it does matter how exactly does it extend. If I try to cut off a corner - it generally works. Move the sketch001 in the attached file for quick testing of when it works and when not. | ||||
A bit of relevant discussion that happened in an irrelevant forum thread: http://forum.freecadweb.org/viewtopic.php?p=69008#p69008 |
I can't reproduce the problem OS: Debian GNU/Linux 7.7 (wheezy) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4189 +7 (Git) Branch: sketcher-geoidcheck,dev-openscad Hash: 3c9b139e7db734e0606a07fda8393b5b42f03b06 Python version: 2.7.3 Qt version: 4.8.2 Coin version: 4.0.0a OCC version: 6.8.0 |
Neither can I. Tried on both Release and Master, both worked as expected. OS: Kubuntu 14.04.1 LTS Word size: 64-bit Version: 0.14.3705 (Git) Branch: releases/FreeCAD-0-14 Hash: f25e6e4716fb63ef3ac618ce9e552761bbc1b4b1 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.7.1 OS: Kubuntu 14.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4191 (Git) Branch: master Hash: a622d14c2d0bdfee6a6de1d09980880094c64978 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.1 |
The bug is gone for me in a recent FreeCAD build. I think it was OCC. Please close the bug. OS: Windows 8.1 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4252 (Git) Branch: master Hash: c02590c666c6dd7d33bf3cb795497311b6badadb Python version: 2.7.8 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.1 |
| 2014-10-31 19:12 | DeepSOIC | New Issue | |
| 2014-10-31 19:12 | DeepSOIC | File Added: pocket-fail.FCStd | |
| 2014-11-14 19:35 | DeepSOIC | Note Added: 0005316 | |
| 2014-11-14 20:37 | shoogen | Note Added: 0005317 | |
| 2014-11-14 20:55 | shoogen | Note Edited: 0005317 | |
| 2014-11-15 18:27 | quick61 | Note Added: 0005319 | |
| 2014-12-08 01:18 | DeepSOIC | Note Added: 0005359 | |
| 2014-12-08 14:27 | shoogen | Status | new => closed |
| 2014-12-08 14:27 | shoogen | Resolution | open => no change required |
