| 0001811 | Arch | Bug | public | 2014-11-01 18:57 | 2015-01-19 17:38 |
| Summary | 0001811: Using "edit placement" function with Arch section planes produces wrong results | ||||
| Description | - rotating it with Draft rotate works normally - editing the Placement property works normally - using the "edit placement" function gives wrong results | ||||
| Additional Information | http://forum.freecadweb.org/viewtopic.php?f=23&t=8204 | ||||
| 2014-11-01 18:57 | yorik | New Issue | |
| 2014-11-01 18:57 | yorik | Assigned To | => yorik |
| 2014-11-01 18:57 | yorik | Status | new => assigned |
| 2014-11-01 18:57 | yorik | Project | FreeCAD => Arch |
| 2015-01-19 17:38 | yorik | Note Added: 0005679 | |
| 2015-01-19 17:38 | yorik | Status | assigned => closed |
| 2015-01-19 17:38 | yorik | Resolution | open => fixed |
| 2015-01-19 17:38 | yorik | Fixed in Version | => 0.15 |
