| 0001820 | Arch | Feature | public | 2014-11-08 14:51 | 2014-12-31 16:40 |
| Summary | 0001820: Arch - Allow all arch objects to move with their host | ||||
| Description | 1. Add a boolean property to all arch object that specifies if they will move together with their host object (if any). 2. Modify the Draft move and Draft rotate tools so they also move/rotate any child that has that property turned on. | ||||
| Additional Information | http://forum.freecad.org/viewtopic.php?f=23&t=8349 | ||||
FreeCAD: master cb5a8079 2014-12-31 17:04:23 Details Diff |
Arch: Added a MoveWithHost property to all Arch objects which specifies if they must be moved/rotated together with their parent - fixes 0001820 |
Affected Issues 0001820 |
| mod - src/Mod/Arch/ArchComponent.py | Diff File | ||
| mod - src/Mod/Arch/ArchWindow.py | Diff File | ||
| 2014-11-08 14:51 | yorik | New Issue | |
| 2014-11-08 14:51 | yorik | Status | new => assigned |
| 2014-11-08 14:51 | yorik | Assigned To | => yorik |
| 2014-11-08 14:51 | yorik | Project | FreeCAD => Arch |
| 2014-12-31 16:40 | yorik | Changeset attached | => FreeCAD Master master cb5a8079 |
| 2014-12-31 16:40 | yorik | Status | assigned => closed |
| 2014-12-31 16:40 | yorik | Resolution | open => fixed |
