| 0001826 | FreeCAD | Feature | public | 2014-11-12 13:49 | 2014-11-17 18:48 |
| Reporter | microelly2 | Assigned To | wmayer | ||
| Summary | 0001826: setEditorMode to read only should block the input | ||||
| Description | its a little bit confusing that I can edit a read only property field and then the value is not stored. user will change these value. a readonly propertiy should be displayed grayed and without focus. | ||||
Can you give an example where this is possible? |
pic 187 - its a read only vector I can click into and see the scroll arrow |
You can see the scroll arrows but can you also change the value of the spin box? |
no, I cannot change the value. that works as expected. |
But then I don't see what should be wrong. It's normal behaviour that you can see scroll arrows in a spin box when it's disabled. And it makes sense this way: just think you have a spin box which gets activated/deactivated by another control (e.g. a check box). If the scroll arrows appeared/disappeared then the text inside would jump in case it's aligned to the right. IMO, that would be an annoying behaviour. |
okay, I understand. So we can close the ticket |
| 2014-11-12 13:49 | microelly2 | New Issue | |
| 2014-11-13 09:33 | wmayer | Note Added: 0005310 | |
| 2014-11-13 20:36 | microelly2 | File Added: bn_186.png | |
| 2014-11-13 20:40 | microelly2 | Note Added: 0005312 | |
| 2014-11-13 21:55 | wmayer | Note Added: 0005313 | |
| 2014-11-14 15:25 | microelly2 | Note Added: 0005314 | |
| 2014-11-14 15:44 | wmayer | Note Added: 0005315 | |
| 2014-11-17 16:26 | microelly2 | Note Added: 0005329 | |
| 2014-11-17 18:48 | wmayer | Status | new => closed |
| 2014-11-17 18:48 | wmayer | Assigned To | => wmayer |
| 2014-11-17 18:48 | wmayer | Resolution | open => won't fix |
