| 0001828 | Sketcher | Bug | public | 2014-11-15 16:11 | 2014-11-17 18:50 |
| Reporter | DeepSOIC | Assigned To | wmayer | ||
| Platform | PC | OS | Any | ||
| Summary | 0001828: Sketcher slot has broken constraints after creation sometimes | ||||
| Description | When creating a Slot shape on a sketch, the resulting geometry sometimes confuses the solver. Symptoms vary: approx 1 of 10 slots drawn is reported to have more than 4 degrees of freedom (I've seen numbers as high as 8), and very occasionally, the slot is not movable by mouse. | ||||
| Steps To Reproduce | 1. create a new sketch 2. click the slot tool on the toolbar and arbitrarily draw a slot with the mouse. 3. look at the number of reported degrees of freedom. 4 is the correct number, the bug is vhen it get higher than 4. 4. (if dof=4) delete the slot and draw a new one. Keep doing this until you get dof>4 5. (for fun!) drag the slot by one of the tangency points and observe the broken coincidence (sometimes). The coincidence is typically restored on the release of the mouse button, and dof becomes the normal =4. | ||||
| Additional Information | The slot typically becomes normal after being moved e.g. by mouse. A guess for the cause: Tangency of line to arc and coincident's Y part should appear redundant in the Jacobian matrix. If so I wonder why isn't it reported. OS: Windows 8.1 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4204 (Git) Branch: Ellipse_final_rebased Hash: bad7aa30b51d651468706560cf4505b339db37c3 Python version: 2.7.5 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.0 OS: Windows 7 (8.1 actually!) Word size: 64-bit Version: 0.14.3700 (Git) Branch: releases/FreeCAD-0-14 Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1 Python version: 2.7.6 Qt version: 4.8.5 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.6.0 (quick61's, probably:) OS: Ubuntu 14.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4202 (Git) Branch: Ellipse_final_rebased Hash: 7f9d89c7edae52afbb02b1c55cdc4e12e9669b48 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.1 | ||||
FreeCAD: master 86a1757c 2014-11-16 20:45:13 Committer: wmayer Details Diff |
Sketcher: Slot: proper tangent constraints Endpoint-to-endpoint tangency is applied now instead of tangency+coincident. Fixes issue 0001828 ( http://freecadweb.org/tracker/view.php?id=0001828 ) |
Affected Issues 0001828 |
| mod - src/Mod/Sketcher/Gui/CommandCreateGeo.cpp | Diff File | ||
| 2014-11-15 16:11 | DeepSOIC | New Issue | |
| 2014-11-15 16:12 | DeepSOIC | Note Added: 0005318 | |
| 2014-11-16 22:41 | wmayer | Changeset attached | => FreeCAD Master master 86a1757c |
| 2014-11-16 23:04 | DeepSOIC | Note Added: 0005325 | |
| 2014-11-17 18:50 | wmayer | Status | new => closed |
| 2014-11-17 18:50 | wmayer | Assigned To | => wmayer |
| 2014-11-17 18:50 | wmayer | Resolution | open => fixed |
| 2014-11-17 18:50 | wmayer | Fixed in Version | => 0.15 |
