| 0001830 | FreeCAD | Bug | public | 2014-11-16 16:23 | 2014-11-17 20:41 |
| Reporter | sourcerer | Assigned To | wmayer | ||
| Platform | Windows 7 | OS | Windows 7 | OS Version | 7 |
| Summary | 0001830: Gui.export() cannot handle long filenames | ||||
| Description | Opening a .stp filename with 86 characters works with ImportGui.open() , but when I replace the .stp with .wrl and try to export it with Gui,export() then the exporting does not work, and I do not get the resulting file. | ||||
| Steps To Reproduce | import FreeCAD import ImportGui import FreeCADGui import os,glob from PySide import QtGui for filename in glob.glob("C:/projects/Elektronik/KiCadprojects/Novena/novena_pvt2_a/Root Entry/Models/*.dat.step"): ImportGui.open(filename) App.setActiveDocument("Unnamed") #Gui.SendMsgToActiveView("ViewFit") wrl = "C:/projects/"+filename[76:-5]+".wrl" #wrl = "C:/Projects/test 2.wrl" #QtGui.QMessageBox.information(None,"Apollo program",str(len(wrl))) Gui.export(App.ActiveDocument.findObjects("Part::Feature"),wrl) QtGui.QMessageBox.information(None,"Apollo program","Written: "+wrl) App.closeDocument(App.ActiveDocument.Name) App.setActiveDocument("") App.ActiveDocument=None Gui.ActiveDocument=None | ||||
I am sorry, the problem was not the long filenames, but the double-extension ".dat.wrl" I have changed the script to output ".wrl" instead of ".dat.wrl" filenames, and now it works correctly. This is not a bug, but an acceptable limitation for me, therefore you can close this bug. |
But an error message like "There is no Export File format for .dat.wrl available" would be helpful I think |
| 2014-11-16 16:23 | sourcerer | New Issue | |
| 2014-11-17 10:33 | sourcerer | Note Added: 0005327 | |
| 2014-11-17 10:37 | sourcerer | Note Added: 0005328 | |
| 2014-11-17 20:41 | wmayer | Changeset attached | => FreeCAD Master master 3904d0a8 |
| 2014-11-17 20:41 | wmayer | Assigned To | => wmayer |
| 2014-11-17 20:41 | wmayer | Status | new => closed |
| 2014-11-17 20:41 | wmayer | Resolution | open => fixed |
