| 0001835 | Arch | Bug | public | 2014-11-21 10:13 | 2015-01-16 19:59 |
| Reporter | rockn | Assigned To | yorik | ||
| Platform | Linux Ubuntu | OS | 14.04 | OS Version | 64 bits |
| Summary | 0001835: Crash when inserting window without support | ||||
| Description | FreeCAD crash when I add Arch window when there is no support (no other object in the Document and when I set the placement to 0 mm,0 mm,0 mm by the taskpanel. jo@jo-desktop-trusty:~/Logiciels/FreeCAD/free-cad-code/woodgalaxy_freecad/cutplane2_build$ gdb ./bin/FreeCAD GNU gdb (Ubuntu 7.7.1-0ubuntu5~14.04.2) 7.7.1 Copyright (C) 2014 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "x86_64-linux-gnu". Type "show configuration" for configuration details. For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/> Find the GDB manual and other documentation resources online at: <http://www.gnu.org/software/gdb/documentation/> For help, type "help". Type "apropos word" to search for commands related to "word"... Reading symbols from ./bin/FreeCAD...(no debugging symbols found)...done. (gdb) run Starting program: /home/jo/Logiciels/FreeCAD/free-cad-code/woodgalaxy_freecad/cutplane2_build/bin/FreeCAD [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1". FreeCAD 0.15, Libs: 0.15R4196 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2014 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## [New Thread 0x7fffde7ee700 (LWP 5445)] [New Thread 0x7fffddfed700 (LWP 5446)] [New Thread 0x7fffd550a700 (LWP 5447)] [New Thread 0x7fffd4d09700 (LWP 5448)] [New Thread 0x7fffcbfff700 (LWP 5450)] [Thread 0x7fffcbfff700 (LWP 5450) exited] Cannot find icon: icons/animation.png [New Thread 0x7fffcbfff700 (LWP 5452)] [New Thread 0x7fff61405700 (LWP 5453)] [New Thread 0x7fff5e3c9700 (LWP 5454)] [New Thread 0x7fff57fff700 (LWP 5455)] [New Thread 0x7fff577fe700 (LWP 5456)] [New Thread 0x7fff56ffd700 (LWP 5457)] Arch workbench activated [Thread 0x7fffd4d09700 (LWP 5448) exited] Program received signal SIGSEGV, Segmentation fault. 0x00007ffff4e25607 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 (gdb) quit A debugging session is active. Inferior 1 [process 5441] will be killed. Quit anyway? (y or n) y | ||||
| Steps To Reproduce | Open FC New Doc -> Arch WB Clic window button Set something else than From Scratch (or not) Clic on the X placement in the taskpanel, Set x = 0 mm, Press Enter, Set y = 0 mm, Press Enter, Set z = 0 mm. Press Enter, -> FreeCAD crash | ||||
| Additional Information | OS: Ubuntu 14.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4196 (Git) Branch: arch-window Hash: 86a1757c2049e9e028525297636a2b1fdfce6006 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.0 | ||||
Indeed it crashes for me too. I'll have a look. |
This doesn't crash anymore for me. Using the "Create from Scratch" without selecting a face simply closes the tool while doing nothing, while selecting one of the presets correctly places the window on screen without parent. Probably one of the other modifications I did solved this together... Is this still crashing for you rockn? |
No, now it's okay ;) |
Ok! Closing then... |
It seem it's come back with latest build. Look like "From scratch" don't crash (and provide nothing) but presets crash with the following message. ./bin/FreeCAD FreeCAD 0.15, Libs: 0.15R4387 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2014 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Arch workbench activated Choisissez une face sur un objet existant, ou sélectionnez un paramètre prédéfini *** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address ffffffffffffffff |
FYI, for me the behaviour is that there is raised an exception which causes the event loop to leave. Qt prints this message: """ Qt has caught an exception thrown from an event handler. Throwing exceptions from an event handler is not supported in Qt. You must reimplement QApplication::notify() and catch all exceptions there. """ |
The problem here seems that the 'receiver' of "GUIApplication::notify (QObject * receiver, QEvent * event)" is a dangling pointer and causes all kind of problems. |
The basic problem is the way how you handle the returnedPressed() signal of the third InputField in the dialog. This is connected somehow with closeDialog() of the task panel which destroys the dialog and all its sub-widgets which makes the pointer to the above InputField a dangling pointer with undefined behaviour. However, I couldn't locate where in your source code returnedPressed() and closeDialog() are connected. |
The culprit is the line FreeCADGui.Control.closeDialog() in the method getPoint() of ArchWindow.py. Actually it's possible to remove this line because the task panel gets closed anyway. If for any reason you need to close the task panel explicitly then you should use the todo.delay function. from DraftGui import todo todo.delay(FreeCADGui.Control.closeDialog,None) |
Thanks for the pointers Werner... I couldn't reproduce the crash again, but indeed this closeDialog() line is unnecessary. I removed it now, let's see if it works... |
Now, when you clic (on a wall) to add a "Create from scratch" window, FreeCAD is asking if I want to close this Dialog because A dialog is already open in the task panel. If I clic No. FreeCAD switch to Sketcher WB, but not in the edit mode of the sketch. I get : Coin error in SoEventManager::processEvent(): Recursive invocation detected. Delay processing event until the current event is finished processing. Traceback (most recent call last): File "<string>", line 1, in <module> <class 'Base.FreeCADError'>: Failed to set object 'Sketch' in edit mode Stack Trace: Traceback (most recent call last): File "<string>", line 1, in <module> Coin warning in SoChildList::traverse(): Detected modification of scene graph layout during action traversal. This is considered to be hazardous and error prone, and we strongly advice you to change your code and/or reorganize your scene graph so that this is not necessary. If I clic Yes: FreeCAD crash with the following message : Choisissez une face sur un objet existant, ou sélectionnez un paramètre prédéfini Arch workbench deactivated Coin error in SoEventManager::processEvent(): Recursive invocation detected. Delay processing event until the current event is finished processing. *** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address 0 |
Hmm this is really hard to solve... The task dialog now gets correctly closed by the Draft GUI itself, but this messes the "create sketch" command that is ran afterwards which gives the problems above. I wonder if it's not easier to simply remove the "create from scratch option"... After all it's not a big deal for the user to create his sketch manually, then run the Arch window command... |
Yes it's a good idea. We have already the ability to "create from scratch" if we have a face selected before run the Arch window command... |
FreeCAD: master a7b3b85a 2015-01-04 18:00:31 Details Diff |
Arch: Fixed the task panel of Windows - fixes 0001835 |
Affected Issues 0001835 |
| mod - src/Mod/Arch/ArchWindow.py | Diff File | ||
FreeCAD: master 90540deb 2015-01-16 20:34:24 Details Diff |
Arch: Removed Create from Scratch option from presets - fixes 0001835 |
| 2014-11-21 10:13 | rockn | New Issue | |
| 2014-11-21 14:43 | yorik | Note Added: 0005336 | |
| 2014-11-21 14:43 | yorik | Assigned To | => yorik |
| 2014-11-21 14:43 | yorik | Status | new => assigned |
| 2015-01-03 16:57 | yorik | Note Added: 0005488 | |
| 2015-01-03 16:57 | yorik | Status | assigned => feedback |
| 2015-01-03 18:38 | rockn | Note Added: 0005491 | |
| 2015-01-03 18:38 | rockn | Status | feedback => assigned |
| 2015-01-03 19:13 | yorik | Note Added: 0005493 | |
| 2015-01-03 19:13 | yorik | Status | assigned => closed |
| 2015-01-03 19:13 | yorik | Resolution | open => fixed |
| 2015-01-03 19:13 | yorik | Fixed in Version | => 0.15 |
| 2015-01-04 09:31 | rockn | Note Added: 0005496 | |
| 2015-01-04 09:31 | rockn | Status | closed => feedback |
| 2015-01-04 09:31 | rockn | Resolution | fixed => reopened |
| 2015-01-04 10:40 | wmayer | Note Added: 0005498 | |
| 2015-01-04 10:47 | wmayer | Note Added: 0005499 | |
| 2015-01-04 11:28 | wmayer | Note Added: 0005500 | |
| 2015-01-04 12:34 | wmayer | Note Added: 0005501 | |
| 2015-01-04 12:34 | wmayer | Note Edited: 0005501 | |
| 2015-01-04 17:06 | yorik | Note Added: 0005507 | |
| 2015-01-04 17:19 | yorik | Changeset attached | => FreeCAD Master master a7b3b85a |
| 2015-01-04 17:19 | yorik | Status | feedback => closed |
| 2015-01-04 23:07 | rockn | Note Added: 0005518 | |
| 2015-01-04 23:07 | rockn | Status | closed => feedback |
| 2015-01-16 19:01 | yorik | Note Added: 0005662 | |
| 2015-01-16 19:05 | rockn | Note Added: 0005663 | |
| 2015-01-16 19:05 | rockn | Status | feedback => assigned |
| 2015-01-16 19:59 | yorik | Changeset attached | => FreeCAD Master master 90540deb |
| 2015-01-16 19:59 | yorik | Status | assigned => closed |
