| 0000185 | FreeCAD | Bug | public | 2010-10-27 08:19 | 2010-12-20 11:11 |
| Summary | 0000185: 0.11.3660 - bug with screen where part is | ||||
| Description | I have build version from subversion 3660 Ubuntu maveric that is running in virtualBox. I have problems because part of screen that draws part is drawn above all menus, other windows that should be above it, even when you suspend system. see picture below | ||||
| Additional Information | Win7 32bit, virtual box, ubuntu 10.10 | ||||
2010-10-27 08:19
Very interesting. Never saw such a strange error. It could be a bug in Maverick or an issue with your OpenGL driver. Can you test this with another OpenGL-based application like Blender? |
i can install Blender, But I've never worked with it. Can you tell me what should I do in it (short tutorial) |
I've installed version 3555 (unstable for windows) and everything is ok. It might be graphic drivers, but I don't know what should I do to make it work on Linux. |
Running an opengl app such as Freecad in a virtualbox machine might indeed give you problems I think. A first thing to try would be to disable all desktop effects (Settings->Appearence->Effects->no effects) because they are also opengl and I think opengl on top of opengl on top of virtualbox might be too much for the system, and another thing would be installing blender, open it, play a bit with the 3D view (rotate it with the middle mouse button etc) and see if no opengl artifact appears. I'm not sure installing 3D drivers in a virtualbox environment would solve much, because the display is also virtual... |
Just tested it on Ubuntu Maverick inside Virtual Box and there is no problem at all. So, it must be an OpenGL problem on your system... |
| 2010-10-27 08:19 | pperisin | New Issue | |
| 2010-10-27 08:19 | pperisin | File Added: FreeCAD.png | |
| 2010-10-27 16:17 | wmayer | Note Added: 0000392 | |
| 2010-10-27 16:22 | wmayer | Relationship added | related to 0000188 |
| 2010-10-27 16:29 | wmayer | Relationship added | related to 0000189 |
| 2010-10-28 19:03 | pperisin | Note Added: 0000395 | |
| 2010-10-30 05:12 | unauthenticated | Note Added: 0000396 | |
| 2010-11-13 19:10 | yorik | Note Added: 0000415 | |
| 2010-11-13 19:10 | yorik | Status | new => feedback |
| 2010-12-20 11:11 | wmayer | Note Added: 0000463 | |
| 2010-12-20 11:11 | wmayer | Status | feedback => closed |
| 2010-12-20 11:11 | wmayer | Resolution | open => not fixable |
