| 0001860 | FreeCAD | Feature | public | 2014-12-17 10:05 | 2015-12-15 13:15 |
| Reporter | piffpoof | Assigned To | wmayer | ||
| Platform | Macintosh | OS | Mac OS X | OS Version | 10.6.8 |
| Summary | 0001860: Can not open a FreeCAD project in FreeCAD by double-clicking the project file on Macintosh | ||||
| Description | Can only start working on a FreeCAD project file by starting FreeCAD and then selecting project file from within FreeCAD. Double-clicking a project file does not open that project within FreeCAD. By Macintosh standards this should open the file in the associated application. | ||||
| Steps To Reproduce | 1 double-click on a FreeCAD project file 2 FreeCAD will start up, but will not open the project file | ||||
| Additional Information | I have associated the .FCStd file extension with the FreeCAD application in the Info box of the Finder: File->Get Info in the Info box "Open WIth:" is set to FreeCAD.app OS: Mac OS X Word size: 64-bit Version: 0.14.3703 (Git) Branch: releases/FreeCAD-0-14 Hash: c6edd47334a3e6f209e493773093db2b9b4f0e40 Python version: 2.7.5 Qt version: 4.8.6 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.7.0 | ||||
Is there a way to determine with which arguments the FreeCAD executable will be started? |
This surpasses my knowledge of FreeCAD on the Macintosh. I am quite happy to look for something if someone can tell me what to look for. For example, is there a command file in the application package that would carry such information? |
What is a "command file"? Isn't the psn argument used for this purpose? http://stackoverflow.com/questions/10242115/os-x-strange-psn-command-line-parameter-when-launched-from-finder |
Well a "command file" is a shell script or file or whatever else might be used to launch an image as a process within the operating system. As far as I can see from reading the Apple Developer page referenced in StackOverflow, the PSN is just the Process ID which the process will need to register itself for system events etc. and possibly to set up communications with other process(es) on the system. But as I understand from reading the page the PSN is a returned value after registering with the Process Manager. I took your initial question to be asking what parameters were passed in when the command line (which could be a shell script) started FreeCAD. The text on the Stack Overflow page "Our OS X Java application which is launched by a shell script inside the MyApp.app bundle gets a strange command line parameter -psn_0_989382 when launched from the Finder" is what I was saying I could look for. I don't know if FreeCAD is launched by a shell script (what I called a command file) inside the FreeCAD app bundle or not. |
The same issue with Mageia Linux, and Freecad 0.13 . I think that the problem, here, is that the " freecad " command doesn't accept any arguments (despite what " man freecad " claims). It could have to do with how the freecad package was build (or compiled). It would be strange, though, for two different operating systems to have the same issue. In Mageia Linux, typing on a terminal, freecad SOMETHING will just start Freecad. For example, the commands freecad --help freecad 001.fcstd freecad --console will all just start Freecad, and the arguments will be, simply, ignored. -------------------------------------- Example of terminal output: [bash 4.2]$ freecad -c FreeCAD 0.13, Libs: 0.13R$WCREV$ © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## -------------------------------------- Additionally, the freecadcmd isn't there: [bash 4.2]$ freecadcmd bash: freecadcmd: command not found -------------------------------------- |
http://qt-project.org/doc/qt-4.8/qfileopenevent.html http://www.qtforum.org/article/23098/how-to-make-my-app-open-a-doc-by-dd-or-doubleclick-on-a-mac.html |
In case it sheds any light on things, I tried what 'nikospap' reported and it seems that with FreeCAD 0.14 on OS X 10.6.8, the FreeCAD image is accepting the parameters, I've appended the Terminal log: --------------------------------- Last login: Mon Dec 29 12:02:29 on ttys000 Intel-Mac-Mini:~ macmini2$ /Applications/FreeCAD/FreeCAD.app/Contents/bin/FreeCADCmd FreeCAD 0.14, Libs: 0.14R3703 (Git) (c) Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## [FreeCAD Console mode <Use Ctrl-D (i.e. EOF) to exit.>] >>> ^D Intel-Mac-Mini:~ macmini2$ Intel-Mac-Mini:~ macmini2$ /Applications/FreeCAD/FreeCAD.app/Contents/bin/FreeCADCmd -h FreeCAD For detailed descripton see http://www.freecad.org Usage: FreeCAD [options] File1 File2 ... Allowed options: Generic options: -v [ --version ] Prints version string -h [ --help ] Prints help message -c [ --console ] Starts in console mode --response-file arg Can be specified with '@name', too Configuration: -l [ --write-log ] Writes a log file to: /Users/macmini2/Library/Preferences/FreeCAD/FreeCAD. log --log-file arg Unlike to --write-log this allows to log to an arbitrary file -u [ --user-cfg ] arg User config file to load/save user settings -s [ --system-cfg ] arg Systen config file to load/save system settings -t [ --run-test ] arg Test level -M [ --module-path ] arg Additional module paths -P [ --python-path ] arg Additional python paths Intel-Mac-Mini:~ macmini2$ Intel-Mac-Mini:~ macmini2$ /Applications/FreeCAD/FreeCAD.app/Contents/bin/FreeCADCmd /Users/macmini2/abc.FCStd FreeCAD 0.14, Libs: 0.14R3703 (Git) (c) Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Importing project files...... Intel-Mac-Mini:~ macmini2$ (100.0 %) Intel-Mac-Mini:~ macmini2$ Intel-Mac-Mini:~ macmini2$ |
http://forum.freecad.org/viewtopic.php?f=3&t=13335&p=106617#p106617 |
FreeCAD: master 76c238fc 2015-11-29 15:36:47 Details Diff |
+ fixes 0001860: Can not open a FreeCAD project in FreeCAD by double-clicking the project file on Macintosh |
Affected Issues 0001860 |
| mod - src/Gui/GuiApplication.cpp | Diff File | ||
| mod - src/Gui/GuiApplication.h | Diff File | ||
| mod - src/MacAppBundle/FreeCAD.app/Contents/Info.plist | Diff File | ||
| 2014-12-17 10:05 | piffpoof | New Issue | |
| 2014-12-17 10:05 | piffpoof | File Added: screen snapshot.jpg | |
| 2014-12-21 15:33 | wmayer | Note Added: 0005417 | |
| 2014-12-21 15:42 | piffpoof | Note Added: 0005418 | |
| 2014-12-21 16:51 | wmayer | Note Added: 0005419 | |
| 2014-12-21 17:05 | piffpoof | Note Added: 0005421 | |
| 2014-12-27 08:28 | nikospap | Note Added: 0005449 | |
| 2014-12-28 18:32 | wmayer | Note Added: 0005458 | |
| 2014-12-29 10:26 | piffpoof | Note Added: 0005462 | |
| 2015-11-28 18:10 | wmayer | Note Added: 0006557 | |
| 2015-11-29 14:37 | wmayer | Changeset attached | => FreeCAD Master master 76c238fc |
| 2015-11-29 14:37 | wmayer | Assigned To | => wmayer |
| 2015-11-29 14:37 | wmayer | Status | new => closed |
| 2015-11-29 14:37 | wmayer | Resolution | open => fixed |
