| 0001864 | FreeCAD | Feature | public | 2014-12-18 13:03 | 2014-12-21 14:29 |
| Reporter | piffpoof | Assigned To | wmayer | ||
| Platform | Macintosh | OS | Mac OS X | OS Version | 10.6.8 |
| Summary | 0001864: The Command key combinations of "Command-." and "Command-D" are missing on the Macintosh version of FreeCAD. | ||||
| Description | On the Macintosh when the user initiates closing a window (either by pressing Command-W or clicking the window close button) where that are unsaved changes , they should be given a user choice dialogue with the 3 buttons: "Don't Save", "Cancel", "Save". They can then either click on one of the buttons or enter the following key combinations: Don't Save Command-D No, don't save my work Cancel Command-. Take me back to the document, I've changed my mind Save Return key Yes, save the changes and close the document The 3-button dialog appears fine on FreeCAD and the 3 buttons work perfectly. However at present the only Command key shortcut that works for the 3 buttons is the Return key, Command-D and Command-. do not work. | ||||
| Steps To Reproduce | 1 start FreeCAD 2 open any window or document and make changes 3 Type the key-combination Command-W to close the window 4 A 3-button dialog will be presented, Command-D and Command-. will not work although the Return key does | ||||
| Additional Information | Command-N, Command-C, Command-V, Command-Z, Command-W and numerous others are present and work perfectly. Some of the key combinations are rather obscure and not worth worrying about. Command-. and Command-D are two that are used every time a document is closed with changes pending so are quite frequently used. | ||||
Could you please provide the version number of Qt, that you used to reproduced the problem. |
Sorry about that... OS: Mac OS X Word size: 64-bit Version: 0.14.3703 (Git) Branch: releases/FreeCAD-0-14 Hash: c6edd47334a3e6f209e493773093db2b9b4f0e40 Python version: 2.7.5 Qt version: 4.8.6 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.7.0 |
I just realised that the Command-. shortcut is not missing from all screens but it is missing from the "Save document before close?" dialog. And as mentioned in the initial report, Control-D is also missing from the same window. I have attached a screen snapshot of the specific dialog window. |
| 2014-12-18 13:03 | piffpoof | New Issue | |
| 2014-12-18 22:16 | shoogen | Note Added: 0005408 | |
| 2014-12-18 22:36 | piffpoof | Note Added: 0005409 | |
| 2014-12-19 06:38 | piffpoof | File Added: screen snapshot.jpg | |
| 2014-12-19 06:38 | piffpoof | Note Added: 0005410 | |
| 2014-12-19 06:40 | piffpoof | Note Edited: 0005410 | |
| 2014-12-21 14:29 | wmayer | Changeset attached | => FreeCAD Master master 366e974b |
| 2014-12-21 14:29 | wmayer | Assigned To | => wmayer |
| 2014-12-21 14:29 | wmayer | Status | new => closed |
| 2014-12-21 14:29 | wmayer | Resolution | open => fixed |
