| 0000187 | FreeCAD | Feature | public | 2010-10-27 08:39 | 2011-04-25 19:02 |
| Summary | 0000187: Dimension of angles and radiuses/diameters | ||||
| Description | I would like to be able to place dimensions on angles and radius/diameters of an arc | ||||
I can add those features to the Draft dimensions |
Angular dimension is now implemented in r4380 (ALT-select 2 edges while drawing the dimension). Still radius & diameter to do... |
There is another small issue. Actually you have to read vertical dimension from "left side of paper". According ISO all dimesion should be readable from down or right http://en.wikipedia.org/wiki/File:Geometric_dimenioning_and_tolerancing-hole.svg Kwahoo |
Oh, indeed... I made everything the other way ;) Time for a preferences setting... |
In latest revision: - dimension texts orientation now follow ISO norm (can be changed in Draft preferences) - diameter dimensions can be added by ALT-selecting a circle or arc - radius dimensions can be added the same way, pressing SHIFT after selecting the object Next steps: - add radius and diameter symbols to dimensions - make all this associative to objects |
done in r4445 |
| 2010-10-27 08:39 | pperisin | New Issue | |
| 2010-10-27 10:24 | yorik | Note Added: 0000390 | |
| 2010-10-27 10:24 | yorik | Status | new => assigned |
| 2010-10-27 10:24 | yorik | Assigned To | => yorik |
| 2011-04-08 20:26 | yorik | Note Added: 0000774 | |
| 2011-04-09 03:11 | unauthenticated | Note Added: 0000775 | |
| 2011-04-09 12:59 | yorik | Note Added: 0000776 | |
| 2011-04-09 15:30 | yorik | Note Added: 0000777 | |
| 2011-04-25 19:02 | yorik | Note Added: 0000802 | |
| 2011-04-25 19:02 | yorik | Status | assigned => closed |
| 2011-04-25 19:02 | yorik | Resolution | open => fixed |
| 2011-04-25 19:02 | yorik | Fixed in Version | => 0.12 |
