| 0001870 | PartDesign | Bug | public | 2014-12-21 16:57 | 2015-01-06 14:29 |
| Reporter | ulrich1a | Assigned To | wmayer | ||
| Summary | 0001870: Revolution and Groove in Part-Design do not hide the sketch and parent-feature for some geometries | ||||
| Description | The revolution and the groove tool do not hide the parent-feature when a sketch with a construction line as revolution axis is applied. This can be reproduced for the stable Version 0.14.3705 and 0.15.4275. See also: http://forum.freecadweb.org/viewtopic.php?f=3&t=8857&p=72843#p72843 and following posts. According to Normandc the bug depends of the type o geometry to start with. | ||||
| Steps To Reproduce | Working in the Part-Design-Workbench with the Task-widget open: - Generate a sketch - pad it to 2 mm. - Selected a side-face - add a sketch to the side-face with a construction line - close the sketch - Chose Part Design Revolution in the Task widget: Select sketch axis 0 and 90° | ||||
| Tags | Part Design | ||||
FreeCAD: master fb19ea50 2015-01-06 15:00:24 Details Diff |
+ fixes 0001870: Revolution and Groove in Part-Design do not hide the sketch and parent-feature for some geometries |
Affected Issues 0001870 |
| mod - src/Mod/PartDesign/Gui/TaskGrooveParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskRevolutionParameters.cpp | Diff File | ||
| 2014-12-21 16:57 | ulrich1a | New Issue | |
| 2014-12-21 16:57 | ulrich1a | File Added: Part_design_error.fcstd | |
| 2014-12-21 17:00 | shoogen | Tag Attached: Part Design | |
| 2015-01-02 18:29 | normandc | Project | FreeCAD => PartDesign |
| 2015-01-06 14:29 | wmayer | Changeset attached | => FreeCAD Master master fb19ea50 |
| 2015-01-06 14:29 | wmayer | Assigned To | => wmayer |
| 2015-01-06 14:29 | wmayer | Status | new => closed |
| 2015-01-06 14:29 | wmayer | Resolution | open => fixed |
