0001875SketcherFeaturepublic2015-01-07 14:30
Reporterr-frank Assigned Tojmaustpc
OSWindowsOS Version7
Product Version0.14
Summary0001875: Highlight End Points of Lines to identify short Lines and "double" Lines
DescriptionWhen having a not-fully-constrained sketch and you are searching for missing constraints
it would be nice to have a function that highlights end points of Lines (Old 2D CAD called
ME10, now Creo Direct Modelling had that functioniality).
This way it would be easier to identify
> small lines created unintended (clicked too fast)
> Lines lying on top of each other
jmaustpc
2015-01-07 14:28
manager   ~0005551
this functionality has already been added in the 0.15dev
Its there in the FreeCAD 0.15dev snapshot releases which you can download and run without installing, hence you can run then as well as your installed release version of FreeCAD.
Please discuss these things in the Help forum before creating tickets.
Generally you would save everyone time if you check if bugs are still there in a dev snap shot rather than only checking in a release version which often end up rather out of date. If you don't want to do that by asking in the help forum, others will do so.
jmaustpc
2015-01-07 14:30
manager   ~0005552
This already exists in 0.15dev and the Windows 0.15dev snapshot releases.
This should have been discussed in the Help forum.
2014-12-26 10:28 r-frank New Issue
2015-01-02 18:28 normandc Project FreeCAD => Sketcher
2015-01-07 14:28 jmaustpc Note Added: 0005551
2015-01-07 14:30 jmaustpc Note Added: 0005552
2015-01-07 14:30 jmaustpc Status new => closed
2015-01-07 14:30 jmaustpc Assigned To => jmaustpc
2015-01-07 14:30 jmaustpc Resolution open => no change required
