| 0001878 | FreeCAD | Bug | public | 2014-12-27 16:15 | 2014-12-28 17:40 |
| Reporter | tanderson69 | Assigned To | wmayer | ||
| Platform | amd64 | OS | Kubuntu | OS Version | 13.10 |
| Summary | 0001878: model refine exception | ||||
| Description | model refine fails with exception due to a null gp_Vec. | ||||
| Steps To Reproduce | Load attached file and run model refine. | ||||
| Additional Information | see backtrace | ||||
The problem is inside the function "wireEncirclesAxis" in the else block which starts with this comment: // Linearize the edge. Idea taken from ShapeAnalysis.cxx ShapeAnalysis::TotCross2D() The problem is that "dv" is the null vector because "begin" and "pend" are identical. This happens in the second iteration "j=2". |
| 2014-12-27 16:15 | tanderson69 | New Issue | |
| 2014-12-27 16:15 | tanderson69 | Status | new => assigned |
| 2014-12-27 16:15 | tanderson69 | Assigned To | => jrheinlaender |
| 2014-12-27 16:15 | tanderson69 | File Added: cut003_bugReport.fcstd | |
| 2014-12-27 16:16 | tanderson69 | File Added: cut003_backtrace.txt | |
| 2014-12-28 16:55 | wmayer | Note Added: 0005457 | |
| 2014-12-28 17:40 | wmayer | Changeset attached | => FreeCAD Master master e329cb5c |
| 2014-12-28 17:40 | wmayer | Assigned To | jrheinlaender => wmayer |
| 2014-12-28 17:40 | wmayer | Status | assigned => closed |
| 2014-12-28 17:40 | wmayer | Resolution | open => fixed |
