| 0001879 | Draft | Bug | public | 2014-12-27 21:02 | 2014-12-29 20:59 |
| Summary | 0001879: Draft->move behaves strangely when snap to working plane is enabled but working plane is 'none' | ||||
| Description | When the working plane is set to 'none' but draft snapping includes the working plane, the snapping while doing for example a "draft->move" seems random. IMHO when the working plane is set to none, the snapping system should ignore the working plane snap option - since snapping is otherwise kind of random, it can take the user a long time to figure out the problem ;-) | ||||
| Steps To Reproduce | 1. Set draft working plane to none, enable snapping to the working plane. 2. Start moving an object and select the starting point. 3. Try putting the object somewhere, snapping will be random. | ||||
| Additional Information | OS: Ubuntu 14.10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4343 (Git) Branch: master Hash: 16a8965038f59fb7dc7d751137dc016999e5728d Python version: 2.7.8 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.0 | ||||
Screenshot shows me trying to move the cylinder on the left (starting point is top center of the cylinder) to the right hand side of the box, snapping to the corner. However, as the UI indicates, the cylinder's top center will not be placed at the corner. |
This is IMHO not a bug. There is always a working plane, which, when it is set to None, adapts to the current view. If you press the "snap to working plane" button, you will indeed snap to that temporary working plane. Maybe what we need to do is change the word "None" for something more meaningful ("Auto" maybe?) |
| 2014-12-27 21:02 | mghansen256 | New Issue | |
| 2014-12-27 21:02 | mghansen256 | File Added: freecad-2014-12-27-draft-move.png | |
| 2014-12-27 21:04 | mghansen256 | Note Added: 0005452 | |
| 2014-12-28 00:29 | yorik | Note Added: 0005456 | |
| 2014-12-28 00:29 | yorik | Assigned To | => yorik |
| 2014-12-28 00:29 | yorik | Status | new => assigned |
| 2014-12-29 20:59 | yorik | Changeset attached | => FreeCAD Master master 638fa8ba |
| 2014-12-29 20:59 | yorik | Status | assigned => closed |
| 2014-12-29 20:59 | yorik | Resolution | open => fixed |
