| 0001891 | Draft | Bug | public | 2015-01-04 13:18 | 2015-01-13 21:20 |
| Reporter | rockn | Assigned To | yorik | ||
| Platform | Linux Ubuntu | OS | 14.04 | OS Version | 64 bits |
| Summary | 0001891: Message Error when adding Draft Dimensions with Continue Mode. | ||||
| Description | This bug don't break anything but could "scared" the user. When you add multiple dimension in a line (continue mode) there is a lot of the same error in Report View. This make that the user think that something is broken. | ||||
| Steps To Reproduce | Clic Add Dimensions button Check Continue mode, Clic on first point, Clic on second point, Clic on the third point (passage point), Clic on the fourth point, Then the View report display a lot of the same warning when mouse is overring the 3d view : <type 'exceptions.IndexError'> Traceback (most recent call last): File "/home/jo/Logiciels/FreeCAD/free-cad-code/woodgalaxy_freecad/master01Janvier2015_build/Mod/Draft/DraftTools.py", line 1833, in action self.node[1] = self.point2 IndexError: list assignment index out of range You still can clic on other point then close the dialog and the Dimensions are well added. | ||||
| Additional Information | OS: Ubuntu 14.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4387 (Git) Branch: master Hash: 26666a1fdabdc08bf8e664bad7173581dc9c1606 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.1.oce-0.16 | ||||
| 2015-01-04 13:18 | rockn | New Issue | |
| 2015-01-04 17:19 | yorik | Note Added: 0005512 | |
| 2015-01-04 17:19 | yorik | Assigned To | => yorik |
| 2015-01-04 17:19 | yorik | Status | new => assigned |
| 2015-01-13 21:20 | yorik | Changeset attached | => FreeCAD Master master 7a710279 |
| 2015-01-13 21:20 | yorik | Status | assigned => closed |
| 2015-01-13 21:20 | yorik | Resolution | open => fixed |
