| 0001892 | Arch | Feature | public | 2015-01-04 14:05 | 2015-01-06 16:10 |
| Reporter | rockn | Assigned To | yorik | ||
| Platform | Linux Ubuntu | OS | 14.04 | OS Version | 64 bits |
| Summary | 0001892: Add mid points to Basepoint property in Arch Frame Object | ||||
| Description | Currently Arch Frame accept only center and vertices of the profil. It should accept mid points of the profil. | ||||
| Additional Information | Could this bug be assigned to myself ? | ||||
Sure! I changed your status to developer. You can now assign bugs to yourself. |
Be careful when changing this, that existing files don't get changed (ie. that Basepoint 1 still points to the same vertex). I'm not sure what's the best way to handle this... Negative numbers maybe? |
hum, as basepoint have been added after 0.14 release, I want to think it's not a problem. Did you use it ? I don't really, even I make improvement on it :s |
Well, as you prefer... It's you who is doing it ;) |
| 2015-01-04 14:05 | rockn | New Issue | |
| 2015-01-04 17:15 | yorik | Assigned To | => rockn |
| 2015-01-04 17:15 | yorik | Status | new => assigned |
| 2015-01-04 17:16 | yorik | Note Added: 0005510 | |
| 2015-01-04 17:18 | yorik | Note Added: 0005511 | |
| 2015-01-05 16:29 | rockn | Note Added: 0005525 | |
| 2015-01-05 18:23 | yorik | Note Added: 0005529 | |
| 2015-01-06 16:10 | yorik | Changeset attached | => FreeCAD Master master 641c295d |
| 2015-01-06 16:10 | yorik | Assigned To | rockn => yorik |
| 2015-01-06 16:10 | yorik | Status | assigned => closed |
| 2015-01-06 16:10 | yorik | Resolution | open => fixed |
