| 0001903 | PartDesign | Bug | public | 2015-01-08 07:41 | 2015-01-08 11:51 |
| Reporter | dawonn | Assigned To | |||
| Platform | x64 | OS | Ubuntu | OS Version | 14.04 LTS |
| Summary | 0001903: Pad dimension requires space between dimension and " symbol. | ||||
| Description | Pad dimension requires space between dimension and " symbol. For example [2"] is interpreted as [2 mm], but [2 "] is correctly interpreted as [2 inch]. | ||||
can you please supply your full FreeCAD version information, as described in http://forum.freecadweb.org/viewtopic.php?f=3&t=5236 as Step 4. or http://forum.freecadweb.org/viewtopic.php?f=3&t=2264 I can not reproduce the problem on OS: Debian GNU/Linux 7.7 (wheezy) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4431 +161 (Git) Branch: yorik/path-module Hash: 0212dde83894752b958229680fb4995f7e0d6ea5 Python version: 2.7.3 Qt version: 4.8.2 Coin version: 4.0.0a OCC version: 6.8.1.dev-4cf9a9f |
You appear to have a newer version. :) I installed from the ppa and thought it was the newest. Should I pull from git and compile my own copy? OS: Ubuntu 14.04.1 LTS Word size: 64-bit Version: 0.14.3702 (Git) Branch: releases/FreeCAD-0-14 Hash: b3368125c63289ec8ce9faec2b2ae4c78d436406 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.7.0 |
You apparently have installed the version of the stable ppa. You can switch to the daily ppa and get the latest version. |
I found it, thanks! Confirmed working, you guys are the best! OS: Ubuntu 14.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4434 (Git) Branch: master Hash: be2e19168122063eb6978f22947ecf4834a5da33 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.1 |
FYI, in 0.14.3702: App.Units.parseQuantity('2"') => 2 App.Units.parseQuantity('2 "') => 50.8 mm in 0.15.4386: App.Units.parseQuantity('2"') => 50.8 mm App.Units.parseQuantity('2 "') => 50.8 mm |
Confirmed for 0.14, fixed in 0.15. |
| 2015-01-08 07:41 | dawonn | New Issue | |
| 2015-01-08 10:25 | shoogen | Note Added: 0005586 | |
| 2015-01-08 10:45 | dawonn | Note Added: 0005588 | |
| 2015-01-08 11:17 | wmayer | Note Added: 0005592 | |
| 2015-01-08 11:20 | dawonn | Note Added: 0005593 | |
| 2015-01-08 11:50 | wmayer | Note Added: 0005594 | |
| 2015-01-08 11:51 | wmayer | Note Added: 0005595 | |
| 2015-01-08 11:51 | wmayer | Status | new => closed |
| 2015-01-08 11:51 | wmayer | Assigned To | => Jriegel |
| 2015-01-08 11:51 | wmayer | Resolution | open => fixed |
| 2015-01-08 11:51 | wmayer | Fixed in Version | => 0.15 |
