| 0001906 | FreeCAD | Feature | public | 2015-01-08 14:53 | 2017-09-30 14:16 |
| Reporter | shoogen | Assigned To | wmayer | ||
| Priority | low | Severity | feature | Reproducibility | N/A |
| Summary | 0001906: add Parameters isRelative, theAngDeflection of BRepMesh_IncrementalMesh in MeshFromShape Gui command | ||||
| Description | expose the additional Parameters isRelative, theAngDeflection of BRepMesh_IncrementalMesh in MeshFromShape taskview gui command. | ||||
| Tags | Mesh, Task View | ||||
Note, in order to create a mesh from a shape the function StlTransfer::BuildIncrementalMesh is used because this creates a valid mesh. However, the problem is that StlTransfer::BuildIncrementalMesh doesn't offer the requested additional parameters. The class BRepMesh_IncrementalMesh may produce triangles where a vertex of one triangle lies on an edge of another triangle which is not allowed for a valid mesh. Since the output triangles of this class is used for display purposes it doesn't matter. |
We could either assure that the shape has allready a triangulation with the wanted angular deflection. Or ask OCCT to change https://github.com/tpaviot/oce/blob/master/src/StlTransfer/StlTransfer.cxx#L120 |
> The class BRepMesh_IncrementalMesh may produce triangles where a vertex of one triangle lies on an edge of another triangle Are you sure whether this is still the case? http://tracker.dev.opencascade.org/view.php?id=25357#c36174 |
No. But anyway, one has to duplicate the whole code of StlTransfer::BuildIncrementalMesh just to be able to pass the angle deflection. |
> But anyway, one has to duplicate the whole code of StlTransfer::BuildIncrementalMesh just to be able to pass the angle deflection. From OCCT 6.8.1 on this will not be an issue anymore. https://github.com/5263/FreeCAD/commit/086201a2ee5a3c60044faeecfdc8e7a2c988b7f8 git://github.com/5263/FreeCAD dev-stlmesh |
https://github.com/FreeCAD/FreeCAD/commit/93c32f0aa93ec622c38293fce9cf7b69c124f778 |
| 2015-01-08 14:53 | shoogen | New Issue | |
| 2015-01-08 14:53 | shoogen | Tag Attached: Task View | |
| 2015-01-08 14:54 | shoogen | Tag Attached: Mesh | |
| 2015-01-11 12:23 | wmayer | Note Added: 0005612 | |
| 2015-01-12 11:23 | shoogen | Note Added: 0005631 | |
| 2015-01-17 14:16 | shoogen | Note Added: 0005666 | |
| 2015-01-17 14:53 | wmayer | Note Added: 0005667 | |
| 2015-02-05 22:56 | shoogen | Note Added: 0005768 | |
| 2015-02-12 13:30 | wmayer | Changeset attached | => FreeCAD Master master cd771f65 |
| 2017-02-10 09:59 | wmayer | Assigned To | => wmayer |
| 2017-02-10 09:59 | wmayer | Status | new => assigned |
| 2017-09-30 14:16 | wmayer | Status | assigned => closed |
| 2017-09-30 14:16 | wmayer | Resolution | open => fixed |
| 2017-09-30 14:16 | wmayer | Fixed in Version | => 0.17 |
| 2017-09-30 14:16 | wmayer | Note Added: 0010220 |
