| 0001908 | Draft | Bug | public | 2015-01-09 20:07 | 2015-01-10 02:00 |
| Platform | Kubuntu Linux | ||||
| Summary | 0001908: Draft move command: shortcuts trigger actions, but are also typed into the value field | ||||
| Description | When a shortcut is triggered using a keystroke, the letter typed is put into the value field as well. There is however a problem that if the typed letter were only used to trigger the shortcut, the user could not type 'cm' into the value field. | ||||
| Steps To Reproduce | 1. Select an object, use the draft move command on it. 2. Press 'c' for continue or copy -> checked state of continue or copy is toggled, but the value for the x coordinate is now also 'c'. | ||||
| Additional Information | OS: Ubuntu 14.10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4387 (Git) Branch: master Hash: 26666a1fdabdc08bf8e664bad7173581dc9c1606 Python version: 2.7.8 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.0 | ||||
| 2015-01-09 20:07 | mghansen256 | New Issue | |
| 2015-01-10 02:00 | yorik | Changeset attached | => FreeCAD Master master 02eecc4f |
| 2015-01-10 02:00 | yorik | Assigned To | => yorik |
| 2015-01-10 02:00 | yorik | Status | new => closed |
| 2015-01-10 02:00 | yorik | Resolution | open => fixed |
