| 0001913 | FreeCAD | Bug | public | 2015-01-12 01:06 | 2015-01-26 14:45 |
| Reporter | more11 | Assigned To | yorik | ||
| Platform | Dell Studio XPS | OS | Windows 7 | OS Version | 64 bit |
| Summary | 0001913: dxf/dwg export doesn't work in 0.15 | ||||
| Description | Using the development version 0.15, the dxf/dwg import/export files are not found. This is the error message: DXF libraries need to be updated. Downloading... The DXF import/export libraries needed by FreeCAD to handle the DXF format were not found on this system. Please either enable FreeCAD to download these libraries (menu Edit > Preferences > Import-Export > DXF > Enable downloads) or download these libraries manually, as explained on https://github.com/yorikvanhavre/Draft-dxf-importer | ||||
| Steps To Reproduce | Download and run latest development release, FreeCAD_0.15.4415_x64_dev_bin. Download https://github.com/yorikvanhavre/Draft-dxf-importer files and put them in C:\Users\<user>\AppData\Roaming\FreeCAD Open file https://dl.dropboxusercontent.com/u/106944188/FreeCAD/dxf_export/200t-adapter.FCStd [^] Mark Shape. Choose "Archive/Export" Save as type : Autodesk DXF | ||||
| Additional Information | OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4415 (Git) Branch: master Hash: ab24e9df6a16db8c87aea1f7b768e70529ff8d82 Python version: 2.7.8 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.1 | ||||
There is now a better description of the procedure you need to follow: http://www.freecadweb.org/wiki/index.php?title=Dxf_Importer_Install |
Also, this is technically not a bug... |
Thanks yorik. Now I get the same bug as in 0.14, which is good. I will be able to export to dxf in next development release hopefully. Maybe the new instructions needs an update? The new tab "Import-Exoprt" is not on the instruction. I had to check the "Allow FreeCAD to automatically download..." |
1. Can we close this bug? 2. Can we lower the severity? |
I updated the instructions on the wiki... I think we can close this bug report. Reopen if needed. |
| 2015-01-12 01:06 | more11 | New Issue | |
| 2015-01-12 01:47 | yorik | Note Added: 0005628 | |
| 2015-01-12 01:48 | yorik | Note Added: 0005629 | |
| 2015-01-12 22:31 | more11 | Note Added: 0005643 | |
| 2015-01-26 14:19 | shoogen | Note Added: 0005737 | |
| 2015-01-26 14:45 | yorik | Note Added: 0005738 | |
| 2015-01-26 14:45 | yorik | Status | new => closed |
| 2015-01-26 14:45 | yorik | Assigned To | => yorik |
| 2015-01-26 14:45 | yorik | Resolution | open => no change required |
| 2015-01-26 14:45 | yorik | Fixed in Version | => 0.15 |
