| 0001916 | Sketcher | Bug | public | 2015-01-12 17:27 | 2015-01-14 23:59 |
| Reporter | Markus B | Assigned To | wmayer | ||
| Platform | Linux | OS Version | wheezy | ||
| Summary | 0001916: Cannot cancel angle constraint dialogue in sketcher | ||||
| Description | Tested on FreeCAD 0.15 git rev 4457; Inserting an angle constraint between two lines in the sketcher brings up a dialogue permitting you to enter/confirm the angle in degrees. I expect the Cancel button (or whatever the translation may be) to close the dialogue without inserting the angle constraint. However, no matter pressing ok or cancel inserts the constraint. Just a very small annoyance. | ||||
| Steps To Reproduce | 1. Open sketcher. 2. Draw two non-parallel lines. 3. Select both lines and insert an angular contraint 4. Dismiss the angle dialogue that popped up | ||||
| duplicate of | 0001648 | closed | Sketcher: New constraints are remain even though cancel is pressed when sketcher asks for length |
Sorry I did miss duplicate 0001648. Anyhow, I guess this bug should also be closed as a won't fix then? |
If you think this behaviour should be changed it might be best to discuss it in the forum. I'll leave the ticket open... I closed the other ticket because there was no response for half a year. |
New topic posted on the FreeCAD forum here; http://forum.freecadweb.org/viewtopic.php?f=8&t=9314 Let's see... |
| 2015-01-12 17:27 | Markus B | New Issue | |
| 2015-01-12 18:40 | wmayer | Relationship added | duplicate of 0001648 |
| 2015-01-13 17:49 | Markus B | Note Added: 0005648 | |
| 2015-01-13 18:29 | wmayer | Note Added: 0005649 | |
| 2015-01-13 22:56 | Markus B | Note Added: 0005651 | |
| 2015-01-14 23:59 | wmayer | Changeset attached | => FreeCAD Master master 17099d05 |
| 2015-01-14 23:59 | wmayer | Assigned To | => wmayer |
| 2015-01-14 23:59 | wmayer | Status | new => closed |
| 2015-01-14 23:59 | wmayer | Resolution | open => fixed |
