| 0001925 | FreeCAD | Feature | public | 2015-01-17 13:58 | 2015-04-11 11:20 |
| Reporter | wvmarle | Assigned To | wmayer | ||
| Summary | 0001925: Preferences not kept well | ||||
| Description | When preferences are set, it is apparently not saved until the software is exited normally, so in case of a crash or a hang after which you have to force close the application, a change in preferences is reset to the old one. I ran into this issue with the Part Design > Shape View > Maximium deviation... setting; haven't tested with others but expect it to be the same. Solution: store preferences the moment they are changed, or the moment the Preferences window is closed, not when the application is closed. | ||||
| Steps To Reproduce | Change a preference in the Edit>Preferences window. Use software until it crashes or until it hangs and do a force close, or simply kill the application forcefully. Restart application. Preference change is not kept. Change again, now close the application normally, and the preference is stored. | ||||
| Additional Information | OS: Linux Mint 17 Qiana Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4484 (Git) Branch: master Hash: f72c802f5daa378298ffbfc3f3a17ec2d35c1816 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.1 | ||||
| 2015-01-17 13:58 | wvmarle | New Issue | |
| 2015-01-22 22:05 | wmayer | Category | Bug => Feature |
| 2015-01-22 22:05 | wmayer | Target Version | => 0.16 |
| 2015-01-23 02:16 | quick61 | Note Added: 0005688 | |
| 2015-01-23 19:09 | wmayer | Changeset attached | => FreeCAD Master master 39aa178b |
| 2015-01-23 19:09 | wmayer | Assigned To | => wmayer |
| 2015-01-23 19:09 | wmayer | Status | new => closed |
| 2015-01-23 19:09 | wmayer | Resolution | open => fixed |
| 2015-04-10 10:12 | wmayer | Relationship added | has duplicate 0002046 |
| 2015-04-11 11:20 | wmayer | Target Version | 0.16 => 0.15 |
