| 0000193 | FreeCAD | Bug | public | 2010-11-02 14:58 | 2010-12-20 13:20 |
| Reporter | mboehne | Assigned To | |||
| Summary | 0000193: hangs upon opening new empty document, 100% cpu | ||||
| Description | I refer to revision 3225 (the one in the Ubuntu repository for u10.10). After starting the programme and opening a new, empty document FC hangs, uses 100% CPU and makes the system unresponsive. The only recovery is ssh by net and a kill -3 on the FC task. FC then types: Coin error in SoNode::GLRenderS(): GL error: 'GL_INVALID_ENUM', nodetype: Separator (set envvar COIN_GLERROR_DEBUGGING=1 and re-run to get more information) Quit After doing this: Coin error in SoSeparator::GLRenderBelowPath(): GL error: 'GL_INVALID_ENUM', nodetype: DirectionalLight Quit | ||||
| Additional Information | Sorry not to check version 0.11, but it insists on installing an NVidia kernel module that brakes my system. | ||||
Just opened the same freecad version here on ubuntu maverick, everything is normal... I think this indicates a problem with your 3D drivers. Can you: - Tell what driver you are using (glxinfo | grep "OpenGL renderer" in terminal) - See if other OpenGL applications such as blender are running correctly |
There must be something strange on your system since it works properly on my Ubuntu Maverick under VirtualBox. > Sorry not to check version 0.11, but it insists on installing an NVidia kernel module that brakes my system. Fro, SF you can get a newer version where the NVidia dependency problem is fixed. |
| 2010-11-02 14:58 | mboehne | New Issue | |
| 2010-11-13 19:00 | yorik | Note Added: 0000413 | |
| 2010-11-13 19:00 | yorik | Status | new => feedback |
| 2010-12-20 13:20 | wmayer | Note Added: 0000464 | |
| 2010-12-20 13:20 | wmayer | Status | feedback => closed |
| 2010-12-20 13:20 | wmayer | Resolution | open => not fixable |
