| 0001932 | FreeCAD | Bug | public | 2015-01-25 18:18 | 2016-08-10 16:16 |
| Reporter | DeepSOIC | Assigned To | DeepSOIC | ||
| Priority | normal | Severity | major | Reproducibility | sometimes |
| OS | Windows | OS Version | 8.1 | ||
| Summary | 0001932: Part revolve produces invalid solid when axis is tilted | ||||
| Description | Imagine the situation. I have a tilted rectangle (sketch) that I have made to produce a cylinder in the right place. I want to use Part Revolve because the sketch is, for example, mapped to a face of something else, but I want a separate cylinder. So, I invoke Part Revolve, select the sketch, the line (an edge of the sketch to serve as the axis of revolution), and get an invalid solid (sometimes). | ||||
| Steps To Reproduce | 1. Create a new sketch. Draw a tilted rectangle. Close. 2. Invoke Part Revolve. Select the sketch to revolve. Hit "Select line in 3D view" button, select an edge of the sketch. Tick "Create Solid" checkbox. Click OK. 3. Check the result. Sometimes, there will be errors like BOPAlgo SelfIntersect. Sometimes, the solid will be valid, but the cylinder will have a tiny hole in it. | ||||
| Additional Information | Looks like there is a loss of precision somewhere. Maybe, the strings appearing in the UI after the axis was selected are read back with those just two decimal digits of precision. Forum thread: http://forum.freecadweb.org/viewtopic.php?f=8&t=9471 OS: Windows 8.1 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4498 +7 (Git) Branch: sketcher-FixReversedGeoms-emulation-squashed Hash: 3e8f7f5738b13dbfbe5b1ef87b8421a3801646b5 Python version: 2.7.8 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.1 | ||||
| Tags | rounding | ||||
the precision of the dialog has been set to two decimal places ever since it addition on 2009-10-15 |
I can confirm DeepSOIC suspicion. I hacked the dialog to ignore the edit boxes and just use the filters location and direction. That cured the problem. |
fixed since commit 50af9efa9f6ef7f7f7018eb77c70013ee5147c06 |
FreeCAD: master 50af9efa 2016-08-08 15:59:25 Details Diff |
PartGui: new Revolve task dialog. Updated to support Axis link, and Symmetric properties. Layout was completely changed. |
Affected Issues 0001932 |
| mod - src/Mod/Part/Gui/DlgRevolution.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgRevolution.h | Diff File | ||
| mod - src/Mod/Part/Gui/DlgRevolution.ui | Diff File | ||
| 2015-01-25 18:18 | DeepSOIC | New Issue | |
| 2015-01-25 18:18 | DeepSOIC | File Added: revolve invalid.FCStd | |
| 2015-01-25 19:43 | shoogen | Relationship added | related to 0001909 |
| 2015-01-25 19:55 | shoogen | Tag Attached: rounding | |
| 2015-01-25 20:18 | shoogen | Note Added: 0005735 | |
| 2015-01-25 20:29 | shoogen | Relationship deleted | related to 0001909 |
| 2015-01-26 01:39 | tanderson69 | Note Added: 0005736 | |
| 2016-08-09 17:52 | DeepSOIC | Note Added: 0007258 | |
| 2016-08-10 16:13 | wmayer | Changeset attached | => FreeCAD Master master 50af9efa |
| 2016-08-10 16:16 | wmayer | Status | new => closed |
| 2016-08-10 16:16 | wmayer | Assigned To | => DeepSOIC |
| 2016-08-10 16:16 | wmayer | Resolution | open => fixed |
| 2016-08-10 16:16 | wmayer | Fixed in Version | => 0.17 |
