| 0001954 | FreeCAD | Bug | public | 2015-02-08 15:31 | 2021-02-06 06:50 |
| Reporter | rockn | Assigned To | wmayer | ||
| Platform | Linux Ubuntu | OS | 14.04 | OS Version | 64 bits |
| Summary | 0001954: Set colors doesn't work on objects that have edit mode reimplemented | ||||
| Description | It seem that Set colors is not working on objects that have their edit mode reimlemented (Arch, Draft, etc) | ||||
| Steps To Reproduce | Create an Arch Object (Wall, Structure...) Right clic on it in the tree view Clic on set colors Instead of having the task panel to change colors per faces the component task widget is open. | ||||
| Additional Information | OS: Ubuntu 14.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4527 (Git) Branch: master Hash: 0da2e4c45a9a259c26abd54c2a35393e1c15696f Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.1.oce-0.16 | ||||
| Tags | colors | ||||
| related to | 0000477 | acknowledged | Proper interface for edit modes of view provider |
|  | In current master from today, "Set colours..." works for Draft Clone does not for Draft Array which give the error message "this object is not editable" Sets an Arch wall into task "Components of this object" and so does Arch Structure and Arch stairs. Building does not have "set colours" in its context menu at all. OS: Ubuntu 12.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6240 (Git) Build type: Debug Branch: master Hash: fa42bc451ab6933a441d7be3680c1d17a25c33e8 Python version: 2.7.3 Qt version: 4.8.2 Coin version: 3.1.3 OCC version: 6.9.1.oce-0.18-dev |
|  | I had a better look at this now, the "set colors" dialog uses the different edit modes system (setEdit() can receive a number, allowing the object to have several different edit modes. This is defined in Mod/Part/ViewProviderExt.cpp L694 However, although that system works in python too (setEdit can receive a number), there is apparently no system to fall back to the C++ setEdit if the python setEdit returns False. (Gui/ViewProviderPythonFeature.cpp L415). If the python setEdit exists, the C++ setEdit is never called, no matter the returned value, unless I'm wrong... I thought about mimicking the ViewProviderExt above (adding a "return Gui::ViewProviderDocumentObject::setEdit(ModNum);" if the python setEdit returns False) but it's apparently not the right way to do. I'll investigate further |
|  | Forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=19989 |
|  | At the moment the whole "edit modes" framework is broken by design. When setting up an edit mode for a view provider then two methods are involved: 1. setupContextMenu where a QAction can be added to a QMenu 2. setEdit(int) where an int of the actual edit mode is passed The difficulty is that inside setupContextMenu a unique integer should be set to the QAction which is still unique when a method invokes the same method of the parent class. And inside setEdit a view provider must know the edit mode numbers it must handle. With the current implementation when a sub-class wants to handle the edit modes of the base class it must know its implementation. When thinking about it I guess it would work if setupContextMenu returns an int which is the number of edit modes it handles. Then the sub-class would know from which value to start with. setEdit should then also return an int and depending on its value a sub-class knows if the base class handled it already. Example (in pseudo code): The only important point is that a programmer has to take care to use the correct values in setEdit to be consistent with setupContextMenu. But he doesn't have to know about the implementation of the base class any more. |
|  | Related to 0000477 |
|  | This ticket has been migrated to GitHub as issue 5611. |
| 2015-02-08 15:31 | rockn | New Issue | |
| 2015-02-08 16:18 | yorik | Summary | Set colors don't work on object where edit mode is modified. => Set colors doesn't work on objects that have edit mode reimplemented |
| 2015-02-08 16:18 | yorik | Description Updated | |
| 2016-01-19 01:55 | yorik | Target Version | 0.16 => |
| 2016-01-20 14:00 | jmaustpc | Note Added: 0006736 | |
| 2016-01-20 14:01 | jmaustpc | Note Edited: 0006736 | |
| 2016-01-31 18:15 | yorik | Note Added: 0006780 | |
| 2017-01-17 20:01 | Kunda1 | Note Added: 0007849 | |
| 2017-01-19 12:20 | wmayer | Relationship added | related to 0000477 |
| 2017-01-19 13:04 | wmayer | Note Added: 0007874 | |
| 2017-01-19 13:05 | wmayer | Assigned To | => wmayer |
| 2017-01-19 13:05 | wmayer | Status | new => assigned |
| 2017-06-07 21:11 | Kunda1 | Tag Attached: colors | |
| 2017-10-02 04:42 | Kunda1 | Note Added: 0010236 | |
| 2019-02-24 18:30 | wmayer | Target Version | => 0.19 |
