| 0001964 | Draft | Patch | public | 2015-02-12 04:52 | 2015-02-12 14:19 |
| Reporter | swill | Assigned To | yorik | ||
| OS | Ubuntu Server | OS Version | 14.04 | ||
| Summary | 0001964: importSVG export fails without GUI | ||||
| Description | When trying to export an SVG file on Ubuntu 14.04 Server without X installed I get the following error: Traceback (most recent call last): File "./custom.py", line 153, in <module> importSVG.export(FreeCAD.ActiveDocument.Objects, "%s/custom.svg" % (config['app']['export'])) File "/usr/lib/freecad/Mod/Draft/importSVG.py", line 1207, in export svg.write(Draft.getSVG(ob)) File "/usr/lib/freecad/Mod/Draft/Draft.py", line 2159, in getSVG (obj.Name,i)) File "/usr/lib/freecad/Mod/Draft/Draft.py", line 1802, in getPath drawing_plane_normal = FreeCAD.DraftWorkingPlane.axis AttributeError: 'module' object has no attribute 'DraftWorkingPlane' This issue is the FreeCAD attribute 'DraftWorkingPlane' is used without checking that it actually exists. Everywhere else in the Draft.py code there is a check before using it and it defaults to the Z axis if it does not exist. I have created a patch for this issue following the same form as the other examples in the same file. I have tested this fix and it works. Cheers and thanks for all the hard work. :) | ||||
0001-Checking-FreeCAD.DraftWorkingPlane.axis-before-using.patch (1,244 bytes)
From f24f1dcde7f36d5cd03f1ae17524f5f1a27c2c4e Mon Sep 17 00:00:00 2001
Date: Wed, 11 Feb 2015 23:41:14 -0500
Subject: [PATCH] Checking 'FreeCAD.DraftWorkingPlane.axis' before using it
src/Mod/Draft/Draft.py | 5 ++++-
1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/src/Mod/Draft/Draft.py b/src/Mod/Draft/Draft.py
index 800af91..68cb516 100644
--- a/src/Mod/Draft/Draft.py
+++ b/src/Mod/Draft/Draft.py
@@ -1799,7 +1799,10 @@ def getSVG(obj,scale=1,linewidth=0.35,fontsize=12,fillstyle="shape color",direct
if rot < -90:
rot += 180
#be carefull with the sweep flag
- drawing_plane_normal = FreeCAD.DraftWorkingPlane.axis
+ if hasattr(FreeCAD,"DraftWorkingPlane"):
+ drawing_plane_normal = FreeCAD.DraftWorkingPlane.axis
+ else:
+ drawing_plane_normal = FreeCAD.Vector(0,0,1)
if plane: drawing_plane_normal = plane.axis
flag_large_arc = (((e.ParameterRange[1] - \
e.ParameterRange[0]) / math.pi) % 2) > 1
1.9.3 (Apple Git-50)
Added the patch, thanks! |
| 2015-02-12 04:52 | swill | New Issue | |
| 2015-02-12 04:52 | swill | File Added: 0001-Checking-FreeCAD.DraftWorkingPlane.axis-before-using.patch | |
| 2015-02-12 13:59 | yorik | Note Added: 0005790 | |
| 2015-02-12 14:19 | yorik | Changeset attached | => FreeCAD Master master cd5783ac |
| 2015-02-12 14:19 | yorik | Assigned To | => yorik |
| 2015-02-12 14:19 | yorik | Status | new => closed |
| 2015-02-12 14:19 | yorik | Resolution | open => fixed |
