| 0001966 | FreeCAD | Bug | public | 2015-02-14 18:03 | 2015-02-25 21:59 |
| Reporter | shoogen | Assigned To | yorik | ||
| Priority | none | Severity | minor | Reproducibility | have not tried |
| Summary | 0001966: edges in Shape2DView extend beyond endpoint | ||||
| Description | The Shape of an Shape2D contains lines that extend beyond the endpoint implied by the hidden line removal. (perhaps the first and last parameter get lost somehow) | ||||
| Steps To Reproduce | recompute the shape of Shape2DView004 and compare it to the imported result from the HLR operation in DRAWEXE | ||||
Drawing Views are not affected! |
Indeed, the result of the Shape2DView is different from Drawing.project()... I'll have a look |
Please merge git://github.com/5263/FreeCAD dev-shape2d https://github.com/5263/FreeCAD/compare/dev-shape2d |
Merged, and the problem appears to be solved. Thanks! |
| 2015-02-14 18:03 | shoogen | New Issue | |
| 2015-02-14 18:03 | shoogen | File Added: hlr-normandc1-iso-shape2dview.png | |
| 2015-02-14 18:07 | shoogen | Note Added: 0005798 | |
| 2015-02-14 18:17 | shoogen | File Added: hlr-test_normandc1-DRAWEXE_result-Shape2DView004.brep | |
| 2015-02-14 18:17 | shoogen | File Deleted: hlr-test_normandc1-DRAWEXE_result-Shape2DView004.brep | |
| 2015-02-14 18:19 | shoogen | File Added: hlr-test_normandc1.fcstd | |
| 2015-02-14 18:20 | shoogen | Steps to Reproduce Updated | |
| 2015-02-15 02:22 | yorik | Note Added: 0005799 | |
| 2015-02-15 02:22 | yorik | Assigned To | => yorik |
| 2015-02-15 02:22 | yorik | Status | new => assigned |
| 2015-02-25 21:05 | shoogen | Note Added: 0005833 | |
| 2015-02-25 21:50 | yorik | Note Added: 0005834 | |
| 2015-02-25 21:59 | yorik | Changeset attached | => FreeCAD Master master 75ced60a |
| 2015-02-25 21:59 | yorik | Status | assigned => closed |
| 2015-02-25 21:59 | yorik | Resolution | open => fixed |
