| 0001972 | FreeCAD | Bug | public | 2015-02-18 04:43 | 2015-02-18 14:19 |
| Reporter | USer1 | Assigned To | wmayer | ||
| Platform | Linux x64 | OS | Ubuntu | OS Version | 14.04 |
| Summary | 0001972: FreeCAD crashes when using keyboard shortcut H to constrain a line | ||||
| Description | Freecad crashes when using the H key to constrain a line horizontally in a sketch | ||||
| Steps To Reproduce | 1. open a sketch 2. make some lines 3. select a line 4. press H on the keyboard to constrain the line horizontally 5. watch as freecad crashes and closes instantly. | ||||
| Additional Information | I've done a backtrace (which you will fine attached) as documented on the wiki pages: http://www.freecadweb.org/wiki/index.php?title=Debugging#Generating_a_Backtrace | ||||
| 2015-02-18 04:43 | USer1 | New Issue | |
| 2015-02-18 04:43 | USer1 | File Added: freecad_backtrace.txt | |
| 2015-02-18 08:21 | USer1 | Note Added: 0005809 | |
| 2015-02-18 14:19 | wmayer | Changeset attached | => FreeCAD Master master 78171d59 |
| 2015-02-18 14:19 | wmayer | Assigned To | => wmayer |
| 2015-02-18 14:19 | wmayer | Status | new => closed |
| 2015-02-18 14:19 | wmayer | Resolution | open => fixed |
