0001985FreeCADBugpublic2015-12-15 13:17
Reporterpfirszt Assigned Towmayer
PrioritylowSeveritytrivialReproducibilityalways
PlatformlinuxOSlinux/fedoraOS Versionfedora 21
Fixed in Version0.16
Summary0001985: cmake doesn't check presence of libtbb.so
Descriptioncmake doesn't check presence of libtbb.so and compilation is crashing with error:
[ 1%] Built target coin
make[2]: *** No rule to make target '/usr/lib64/libtbb.so', needed by 'lib/libDriver.so'. Stop.
CMakeFiles/Makefile2:334: recipe for target 'src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/all' failed
make[1]: *** [src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/all] Error 2
Makefile:117: recipe for target 'all' failed
make: *** [all] Error 2
Steps To Reproducerun 'make' without tbb-devel installed on fedora 21
Additional InformationInstalling tbb-devel fixes the problem, but it should be checked by cmake
2015-03-01 14:38
administrator   ~0005843
FreeCAD doesn't use tbb at all. But oce might be built with tbb enabled and FreeCAD cannot check this easily. Is oce under Fedora built with tbb support?
pfirszt
2015-03-01 17:22
developer   ~0005846
Yes, as far as I can tell:
$ rpm -qa | grep OCE
OCE-draw-0.16-1.fc21.1.x86_64
OCE-modeling-0.16-1.fc21.1.x86_64
OCE-visualization-0.16-1.fc21.1.x86_64
OCE-ocaf-0.16-1.fc21.1.x86_64
OCE-foundation-0.16-1.fc21.1.x86_64
OCE-devel-0.16-1.fc21.1.x86_64
fedora-lan:/home/przemo/fedora/FreeCAD/freecad
$ rpm -qa --requires OCE-modeling | grep tbb
libtbb.so.2()(64bit)
$ rpm -qa --requires OCE-foundation | grep tbb
libtbbmalloc.so.2()(64bit)
Section of OCE.spec file for feodra:
%ifnarch %arm
  %if 0%{?rhel}
BuildRequires: openmpi-devel
  %else
BuildRequires: tbb-devel
  %endif
%endif
2015-04-19 09:49
administrator   ~0006046
IMO, this should be reported to the package maintainers of oce (on the various distributions) to add a dependency to tbb-devel for the devel package of oce.
2015-03-01 13:19 pfirszt New Issue
2015-03-01 14:38 wmayer Note Added: 0005843
2015-03-01 15:22 wmayer Status new => feedback
2015-03-01 17:22 pfirszt Note Added: 0005846
2015-03-01 17:22 pfirszt Status feedback => new
2015-04-19 09:49 wmayer Note Added: 0006046
2015-09-12 13:31 wmayer Status new => closed
2015-09-12 13:31 wmayer Assigned To => wmayer
2015-09-12 13:31 wmayer Resolution open => not fixable
2015-12-15 13:17 yorik Fixed in Version => 0.16
