| 0001988 | FreeCAD | Bug | public | 2015-03-02 13:29 | 2017-01-22 21:49 |
| Reporter | shoogen | Assigned To | |||
| Priority | none | Severity | major | Reproducibility | always |
| Summary | 0001988: Mefisto Mesh fails with error 13 | ||||
| Description | Mefisto can't mesh the attached face and fails with the message: MEFISTO_2D failed on subshape #1 with error 13 "Error in Triangulation (aptrte())" | ||||
| Tags | Mesh, SMESH | ||||
The netgen mesh also reports an error but gives at least a result: NETGEN_2D failed on subshape # 2 with error COMPERR_ALGO_FAILED "Problem in Surface mesh generation" The critical part of the shape is where the hole touches the boundary in a single point. The meshing algorithm has to create two triangles that share a common point but not a common edge. However, in some literature about mesh structures this is considered invalid -- called a "non-manifold vertex". So maybe, this could be the reason why Mefisto doesn't return anything. And when you zoom-in deep enough into the mesh that netgen generates you will see that there is a little gap. |
| 2015-03-02 13:29 | shoogen | New Issue | |
| 2015-03-02 13:29 | shoogen | File Added: face-mefisto-tp1.brep | |
| 2015-03-02 13:29 | shoogen | Tag Attached: SMESH | |
| 2015-03-02 13:29 | shoogen | Tag Attached: Mesh | |
| 2015-03-02 14:36 | wmayer | Note Added: 0005849 | |
| 2015-03-02 14:37 | wmayer | Note Edited: 0005849 | |
| 2017-01-22 21:49 | wmayer | Status | new => closed |
| 2017-01-22 21:49 | wmayer | Resolution | open => not fixable |
