| 0001990 | FreeCAD | Bug | public | 2015-03-03 00:17 | 2016-07-23 10:30 |
| Reporter | brycenesbitt | Assigned To | wmayer | ||
| Priority | high | Severity | tweak | Reproducibility | always |
| Platform | Linux | ||||
| Summary | 0001990: Undo does not work for 'toggle visibility' | ||||
| Description | Undo does not work for 'toggle visibility' | ||||
| Steps To Reproduce | 1) Select an object 2) Press "space" to toggle the visibility. 3) Change your mind: press undo and nothing happens. | ||||
| Additional Information | Toggle visibility is a feature a starting user will likely use: having an undo path is nice. | ||||
| Tags | undo | ||||
| child of | 0000020 | closed | UndoRedo for Gui Elements |
Undo/redo of view providers is now supported and as a test I implemented it for the show/hide command. However, it appeared that this is rather annoying since it pollutes the transaction history. So, we decided not to implement this request. Btw, with the workflow in the new PartDesign module this is obsolete anyway because the show/hide is done automatically wherever possible. |
| 2015-03-03 00:17 | brycenesbitt | New Issue | |
| 2015-03-03 00:20 | brycenesbitt | Tag Attached: undo | |
| 2015-03-03 09:29 | wmayer | Relationship added | child of 0000020 |
| 2016-07-23 10:30 | wmayer | Note Added: 0007210 | |
| 2016-07-23 10:30 | wmayer | Status | new => closed |
| 2016-07-23 10:30 | wmayer | Assigned To | => wmayer |
| 2016-07-23 10:30 | wmayer | Resolution | open => won't fix |
| 2016-07-23 10:30 | wmayer | Fixed in Version | => 0.17 |
