| 0002002 | FreeCAD | Bug | public | 2015-03-12 15:44 | 2016-01-19 14:21 |
| Reporter | quick61 | Assigned To | ian.rees | ||
| Summary | 0002002: Mesh Faces Not Conforming With Tessellation Settings | ||||
| Description | When exporting mesh, (.stl) or rendering with POV-Ray, mesh faces are not adhering to the setting defined in the tessellation max deviation setting. | ||||
| Steps To Reproduce | Create a Sphere in the Part Workbench. Export Sphere as mesh with default tessellation setting - 0.5 Export Sphere as mesh with new tessellation setting - 0.01 Faces of exported mesh are the same. | ||||
| Additional Information | See forum thread - http://forum.freecad.org/viewtopic.php?f=3&t=10086 | ||||
Sorry, forgot this - OS: Kubuntu 14.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4648 (Git) Branch: master Hash: 0063b8093768825ba954ec84cc9ebd19f766b50a Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
In Mesh module's exporter() method (defined in src/Mod/Mesh/App/AppMeshPy.cpp ) , there's a line: float fTolerance = 0.1f; I suspect that's the problem - it ends up getting passed on to OCC/OCE for exporting regular parts. My inclination (haven't thought about this too much) is to add a preferences page for the mesh module, any thoughts? |
the tessellation max deviation is a visual setting, I think it should not be used for mesh conversion (it could easily lead to huge conversions that could block the whole thing). I think Ian's suggestion is good. Ideally all the meshing options of the Mesh WB should be made available. I did something like that for the DAE format (enable arch WB and look in preferences). This could actually be used for all implicit Part to Mesh conversions... |
I've started working on adding a tab for "Mesh Formats" under the "Import-Export" preferences section to address this. Edit: Pull request https://github.com/FreeCAD/FreeCAD/pull/78 |
FreeCAD: master b6a1fd85 2016-01-19 08:44:17 Details Diff |
Added ability to change mesh export tolerance. |
Affected Issues 0002002 |
| mod - src/Mod/Mesh/App/AppMeshPy.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/AppMeshGui.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/CMakeLists.txt | Diff File | ||
| add - src/Mod/Mesh/Gui/DlgSettingsImportExport.ui | Diff File | ||
| add - src/Mod/Mesh/Gui/DlgSettingsImportExportImp.cpp | Diff File | ||
| add - src/Mod/Mesh/Gui/DlgSettingsImportExportImp.h | Diff File | ||
FreeCAD: master f4807914 2016-01-19 14:25:16 Details Diff |
Made last commit non-C++11 compatible |
| mod - src/Mod/Mesh/Gui/DlgSettingsImportExportImp.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/DlgSettingsImportExportImp.h | Diff File | ||
| 2015-03-12 15:44 | quick61 | New Issue | |
| 2015-03-12 15:46 | quick61 | Note Added: 0005863 | |
| 2015-03-12 15:47 | quick61 | Note Edited: 0005863 | |
| 2015-12-19 07:32 | ian.rees | Note Added: 0006618 | |
| 2015-12-20 23:20 | yorik | Note Added: 0006621 | |
| 2016-01-18 09:46 | ian.rees | Note Added: 0006729 | |
| 2016-01-19 08:12 | ian.rees | Assigned To | => ian.rees |
| 2016-01-19 08:12 | ian.rees | Status | new => assigned |
| 2016-01-19 08:14 | ian.rees | Note Edited: 0006729 | |
| 2016-01-19 14:20 | wmayer | Changeset attached | => FreeCAD Master master b6a1fd85 |
| 2016-01-19 14:20 | wmayer | Changeset attached | => FreeCAD Master master f4807914 |
| 2016-01-19 14:21 | wmayer | Status | assigned => closed |
| 2016-01-19 14:21 | wmayer | Resolution | open => fixed |
| 2016-01-19 14:21 | wmayer | Fixed in Version | => 0.16 |
