| 0002010 | FreeCAD | Bug | public | 2015-03-20 12:07 | 2015-03-20 18:34 |
| Reporter | plgarcia | Assigned To | shoogen | ||
| Platform | Windows 7 French | OS | Windows 7 | OS Version | Pro and |
| Summary | 0002010: Import SVG problems | ||||
| Description | The profile is not correctly loaded. See the attache file and description | ||||
| Steps To Reproduce | Import the svg file. 2 examples available in attached zip file. | ||||
i can't reproduce the problem in 20 ext 0.5 file. (in the current development version) The Problem with the Ce Shape is reproduce-able in 0.15.4664. >>> App.ActiveDocument.Ce.Shape.Edges [<Edge object at 0x10e05a20>, <Edge object at 0x10e1ef90>] >>> App.ActiveDocument.Ce.Shape.Edges[0].Curve Circle (Radius : 518.236, Position : (0, 517.95, 0), Direction : (0, -0, -1)) >>> App.ActiveDocument.Ce.Shape.Edges[1].Curve Circle (Radius : 518.236, Position : (0, -517.95, 0), Direction : (0, 0, -1)) |
I think that the path for the "Ce" object is invalid. It should be "M 40,0 A 40,40 0 0 1 -40,0 40,40 0 0 1 40,0" But actually the radii are set to 0.664370078737 (instead of 40) How was this file generated? |
Yes your are right for CE path. Sorry for that. I just tested the 20 ext 0.5 file with the 0.15.4664 and the problem is still there. But may be is it due to an approximation. When the radii are not exactly what they should be then the consequences are "visible". InkScape may use different algorithms that may be more robust. So it is able to view properly the ce path even with this stupid error, and the 20 ext 0.5 gear too. I have been searching for others svg problems in the database, and may be some are related. Thanks anyway. |
regarding the 20 ext 0.5 file. The details are very fine (about 20µm) perhaps you can select the draft workbench and increase the draft workbench precision. I usually use 6 decimal places. |
yes this is it. Set the precision ! Many thanks and sorry for disturbing |
If you are not sure if some behavior is an actual bug, please consider bringing the question up in the forum first. |
| 2015-03-20 12:07 | plgarcia | New Issue | |
| 2015-03-20 12:07 | plgarcia | File Added: bugFreecad1.zip | |
| 2015-03-20 15:46 | shoogen | Note Added: 0005883 | |
| 2015-03-20 15:46 | shoogen | Assigned To | => shoogen |
| 2015-03-20 15:46 | shoogen | Status | new => assigned |
| 2015-03-20 16:15 | shoogen | Note Added: 0005884 | |
| 2015-03-20 16:15 | shoogen | Status | assigned => feedback |
| 2015-03-20 17:15 | plgarcia | Note Added: 0005885 | |
| 2015-03-20 17:15 | plgarcia | Status | feedback => assigned |
| 2015-03-20 17:20 | shoogen | Note Added: 0005886 | |
| 2015-03-20 17:21 | shoogen | Status | assigned => feedback |
| 2015-03-20 17:28 | plgarcia | Note Added: 0005887 | |
| 2015-03-20 17:28 | plgarcia | Status | feedback => assigned |
| 2015-03-20 18:34 | shoogen | Note Added: 0005888 | |
| 2015-03-20 18:34 | shoogen | Status | assigned => closed |
| 2015-03-20 18:34 | shoogen | Resolution | open => no change required |
