| 0002011 | FreeCAD | Bug | public | 2015-03-20 12:15 | 2015-03-20 12:23 |
| Reporter | plgarcia | Assigned To | ickby | ||
| Platform | Windows | OS | Windows 7 | ||
| Summary | 0002011: Cut with an array does not work if the patterns overlay. Calculation is very long, and the result is incorrect. | ||||
| Description | I made it minor becaus it is always possible to make different objects, then make a fusion instead using an array. | ||||
| Steps To Reproduce | A very simple project reproducing the problen is given | ||||
This is expected behaviour, parts of an array should not overlap (selfintersections are not allowed). In 0.15 there is a new property in the array which allows to fuse all individual parts in it, this is intended to be used for situations as you present here. |
| 2015-03-20 12:15 | plgarcia | New Issue | |
| 2015-03-20 12:15 | plgarcia | File Added: BugFreeCad2.zip | |
| 2015-03-20 12:23 | ickby | Note Added: 0005881 | |
| 2015-03-20 12:23 | ickby | Status | new => closed |
| 2015-03-20 12:23 | ickby | Assigned To | => ickby |
| 2015-03-20 12:23 | ickby | Resolution | open => fixed |
| 2015-03-20 12:23 | ickby | Fixed in Version | => 0.15 |
