| 0002014 | FreeCAD | Bug | public | 2015-03-20 14:29 | 2015-05-15 19:23 |
| Reporter | tanderson69 | Assigned To | tanderson69 | ||
| Platform | amd64 | OS | Kubuntu | OS Version | 14.10 |
| Target Version | 0.16 | Fixed in Version | 0.16 | ||
| Summary | 0002014: Part offset with fill option produces an invalid shape | ||||
| Description | When using the part offset command on a face or sheet with the fill option on, we are not getting "connected" perimeter faces. | ||||
| Steps To Reproduce | Just took a face from a default box and ran it through part offset. | ||||
| Additional Information | You can see in the shape content from the picture that we have too many edges. We have 16 when we should have 12. It is pretty obvious why this is happening. We are letting BRepOffsetAPI_ThruSections build the end edges(edges not on the origin or offset faces) for each face. I can think of 2 solutions at the moment. 1) run the results through a sewing algorithm. I would think the end edges would coincide enough for this to be successful. 2) pass entire perimeter wires to BRepOffsetAPI_ThruSections and call once for operation. It appears that sewing was attempted at one time. Comments? This is an example where the BOPAlgo geometery checks have come in real handy! | ||||
Please review and merge. assuming origin is sourceforge. git fetch origin && git cherry-pick 671610f |
sorry, i should use cherry-pick more careful ;) merges well. |
Could this be merged to the Release-0.15 branch? It would make Part Offset much more useful. |
When testing this with a box as input shape the message "no closed bounds" is printed and a null shape is returned. It might be better to throw an exception in this case because now the Offset feature is valid but has no data. |
It didn't appear that throwing exceptions out of toposhape was standard practice. So I was cautious and just returned empty shapes. If you think we should throw exceptions, then lets do it. |
OK, I will merge your branch and make the needed changes. Btw, there are a few places in TopoShape where exceptions are thrown using OCC's Standard_Failure::Raise mechanism. |
| 2015-03-20 14:29 | tanderson69 | New Issue | |
| 2015-03-20 14:29 | tanderson69 | Status | new => assigned |
| 2015-03-20 14:29 | tanderson69 | Assigned To | => tanderson69 |
| 2015-03-20 14:29 | tanderson69 | File Added: offset.png | |
| 2015-03-21 13:43 | tanderson69 | Note Added: 0005895 | |
| 2015-03-21 19:10 | shoogen | Note Added: 0005898 | |
| 2015-03-21 19:21 | shoogen | Note Edited: 0005898 | |
| 2015-03-22 17:33 | normandc | Note Added: 0005916 | |
| 2015-05-11 17:02 | tanderson69 | Resolution | open => fixed |
| 2015-05-11 17:05 | tanderson69 | Status | assigned => resolved |
| 2015-05-15 15:56 | wmayer | Note Added: 0006137 | |
| 2015-05-15 16:33 | wmayer | Note Edited: 0006137 | |
| 2015-05-15 16:43 | tanderson69 | Note Added: 0006139 | |
| 2015-05-15 16:43 | tanderson69 | Status | resolved => feedback |
| 2015-05-15 16:43 | tanderson69 | Resolution | fixed => reopened |
| 2015-05-15 17:59 | wmayer | Note Added: 0006140 | |
| 2015-05-15 19:20 | wmayer | Changeset attached | => FreeCAD Master master 0950e196 |
| 2015-05-15 19:23 | wmayer | Status | feedback => closed |
| 2015-05-15 19:23 | wmayer | Resolution | reopened => fixed |
| 2015-05-15 19:23 | wmayer | Fixed in Version | => 0.16 |
