| 0002015 | Sketcher | Bug | public | 2015-03-20 23:03 | 2015-12-15 13:18 |
| Reporter | riX | Assigned To | abdullah | ||
| OS | Linux x86_64 | OS Version | 3.18.6-1-ARCH | ||
| Summary | 0002015: Crash when setting equal constraint on too many elements. | ||||
| Description | Selecting 14 or more arc elements in sketch and adding equal constraint crashes FreeCAD. The first 13 are created one by one, and when number 14 should have been set, there is a crash. | ||||
| Steps To Reproduce | Select all 15 arcs in the attached sketch, press equal constraint. | ||||
Forgot version, it's: OS: Linux Word size: 64-bit Version: 0.14.3702 (Git) Branch: releases/FreeCAD-0-14 Hash: b3368125c63289ec8ce9faec2b2ae4c78d436406 Python version: 2.7.9 Qt version: 4.8.6 Coin version: 3.1.3 SoQt version: 1.5.0 |
The version you are using is quite old. I have downloaded your sketch, selected all the arcs, applied an equality constraint. It takes some time (maybe 15 seconds), but all the constraints get applied and I have no crash. I have used one of the latest Ubuntu PPA: OS: Ubuntu 14.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.5342 (Git) Build type: None Branch: master Hash: 790714712a145bdd8370a68bbcca201ecc4ba6c4 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 My only advice would be to get a newer version of FC, as this seems fixed. |
I am closing this ticket to keep things tidy. If you need help installing a newer version on your system feel free to open a thread in the FC user forum. Feel free to reopen it if you want to submit any further information. |
The issue is no longer present in current PPA/master. |
| 2015-03-20 23:03 | riX | New Issue | |
| 2015-03-20 23:03 | riX | File Added: housing.fcstd | |
| 2015-03-20 23:09 | riX | Note Added: 0005890 | |
| 2015-08-16 06:29 | abdullah | Assigned To | => abdullah |
| 2015-08-16 06:29 | abdullah | Status | new => assigned |
| 2015-08-16 09:26 | abdullah | Note Added: 0006289 | |
| 2015-08-16 09:29 | abdullah | Note Added: 0006290 | |
| 2015-08-16 09:30 | abdullah | Note Added: 0006291 | |
| 2015-08-16 09:30 | abdullah | Status | assigned => closed |
| 2015-08-16 09:30 | abdullah | Resolution | open => fixed |
