| 0002016 | Draft | Bug | public | 2015-03-21 03:36 | 2015-12-15 13:18 |
| Reporter | bgpoythress | Assigned To | yorik | ||
| Platform | Dell Inspiron 3542 | OS | Ubuntu | OS Version | 14.04 |
| Summary | 0002016: Annotation using draft workbench causes crash | ||||
| Description | Once an annotation is created. If it is edited in the data tab of the left information pane, and an empty line is placed between lines of text, the application crashes once the command is completed. Either empty lines should not be accepted in the annotation edit window, or the function should handle the empty line without crashing. Thanks. | ||||
| Steps To Reproduce | create annotation text-> with text selected, select the data tab-> select the label text edit button labelled "..."-> create multiple lines of text with an empty line in between->complete command -> crash | ||||
| 2015-03-21 03:36 | bgpoythress | New Issue | |
| 2015-03-21 16:57 | yorik | Note Added: 0005896 | |
| 2015-03-21 16:57 | yorik | Assigned To | => yorik |
| 2015-03-21 16:57 | yorik | Status | new => assigned |
| 2015-09-01 14:49 | yorik | Changeset attached | => FreeCAD Master master 9426a776 |
| 2015-09-01 14:49 | yorik | Status | assigned => closed |
| 2015-09-01 14:49 | yorik | Resolution | open => fixed |
