| 0002040 | FreeCAD | Feature | public | 2015-04-07 15:21 | 2015-12-15 13:18 |
| Reporter | larsen | Assigned To | yorik | ||
| Summary | 0002040: Revert to saved | ||||
| Description | There are some programs that have a "Revert to Saved" function, which simply closes and reopens a file. So, if you messed up your model, you simply reload it. Sounds lazy as the current way is not much longer, but once you have this, you will appreciate it. | ||||
| 2015-04-07 15:21 | larsen | New Issue | |
| 2015-04-08 22:24 | yorik | Note Added: 0005979 | |
| 2015-04-08 22:24 | yorik | Assigned To | => yorik |
| 2015-04-08 22:24 | yorik | Status | new => assigned |
| 2015-06-15 02:00 | yorik | Changeset attached | => FreeCAD Master master 1749ff2d |
| 2015-06-15 02:00 | yorik | Status | assigned => closed |
| 2015-06-15 02:00 | yorik | Resolution | open => fixed |
